Drivers side lock problems - 2014 Prius 4
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Barry Rodriguez, May 16, 2020.
  1. Barry Rodriguez
    Barry Rodriguez New Member
    Noblesville, IN
    Hello!
    For the last year or so, the driver's side door of my 2014 Prius 4 (89k miles) has not locked or unlocked properly when using the fob. I've scoured the forums here and found many with a similar problem and suggestions of a bad actuator or bad 12v battery.
    So, I replaced the actuator (with a refurbished one on Ebay). I also replaced my 12v battery (which was running low anyway, so needed replacement). The problem has not gone away. I would appreciate any help you can give!
    Here are the facts:
    • When I hit 'unlock' on my key fob, the drivers door rarely unlocks (90% of the time I have to reach through the back door to unlock it). Sometimes the turn signals flash in unison three times when I'm trying to unlock.
    • When I hit 'lock' on my key fob, the drivers door does NOT lock (although the other doors do), and the car emits a long beep.
    • The same problems can be replicated with the 'smart key' features on the door handle (touching the lock/unlock portions of the handle while the key fob is nearby)
    • The passenger side door seems unaffected and works normally with both the fob and the 'smart key' features.
    • The driver's side door CAN be manually locked and unlocked with both a physical key and the toggle switch inside.
    Any theories on what might be happening? Is it possible both the actuator in the car AND the replacement were both faulty? Could there be some kind of wiring issue? I'm stumped.
    Thanks in advance for any insight you can give!
    52,693
    welcome!
    what about the interior electric switch on the armrest?
    is is possible that you got a bad actuator, or maybe something is binding
  3. Barry Rodriguez
    Noblesville, IN
    I wasn't aware there was an electric switch on the armrest! Where can I find that? Is that on the door panel that I remove? Or inside the door body?
    It's definitely possible the actuator I got was faulty, but both actuators made the same clunking noises occasionally, when trying to unlock. I looked for binding in all the moving parts I could reach, but everything seemed to be moving fine.
  4. Barry Rodriguez
    Noblesville, IN
    Oh, duh. I just realized you mean the lock/unlock switch on the armrest. Yeah, it works fine and does the same things when I click it as when I click the key fob.
  5. bisco
    52,693
    if it works once in a while, and the door switch, fob button and sks all do the same thing, it seems to me that it has to be binding or the motor. maybe i'm missing something, but i would think if there was a wiring or ecu problem, it wouldn't make the sound like it's trying to move.
    does the manual lock inside the door wiggle at all when you hear the clunk?
  6. Gymteacher1
    Gymteacher1 Junior Member
    Milwaukee
    Hello!
    Did you ever figure out the problem?? My 2015 Prius V sometimes doesn't unlock the drivers door and the rest unlock. sometimes it works and sometimes not! Thanks
