Driver's vanity light out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rlongenbach, Jul 12, 2006.
  1. rlongenbach
    rlongenbach New Member
    Okay. Changed the bulb, and it still doesn't work.
    Looked at the compartment and hood fuse boxes and didn't see anything for just vanity lights or the drivers side only!
    My guess is that it needs to be replaced. Did I miss a fuse?
  2. Tideland Prius
    16,445
    Do you know about the switch and the fact the mirror cover has to be fully opened before the light turns on?
  3. rlongenbach
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 12 2006, 07:21 PM) [snapback]285328[/snapback]</div>
    Yes. The passenger side works with no problems.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    swap bulb with pass side, i think you will find its the switch and not the bulb.
  5. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Re: Driver's vanity light out
    Just so I understand . To check the vanity light the following need to occur. Visor down and mirror slot cover in open position. Additionally does the vehicle IGN need to be on or not???
  6. Planet Awesum
    Planet Awesum Junior Member
    26
    32
    Portland, Oregon
    I found moving the visor a little back and forth worked. Had the light in "on" position. Mirror open. Even exchanged each housing since the drivers side worked and passenger side didn't.
    Was doing the led interior light replacement bought off eBay for about $8. Looks amazing and now I'm finally complete, thank god.
  7. bisco
    51,149
    well done sir.(y)
  8. Ozzbo
    Ozzbo New Member
    29
    Austin
    How to get to the bulb? I can’t extract it
