Driver's window air noise
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by glh, Jun 21, 2016.
  1. glh
    glh Junior Member
    Vail, Arizona
    Four Touring
    Anyone else having a problem with air noise coming the driver's window? If so, any solutions found?
    49,489
    why not have the dealer fix it while it's still under warranty?
  3. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Noise can be subjective.
    An easy test is to take a dollar bill (paper money) and place it between the door/ window frame and weatherstrip.
    Ditto door glass to weatherstrip channel.
    (Repair shop tests utilize smoke and or water machines/ tools.)
    If you find an area where the bill has less friction, that could be the source of your air/ wind noise.
    Window mechanisms in many cars typically has fore aft plus, tilt plus in and out adjustments.
    This can be a do it yourself project, yet experience makes this easier...it is a puzzle of alignments.
    Door frame is no adjustment really other than "messing" with the hinges or physically bending the frame. Most replace the weatherstrip and if the air leak noise continues it may be best to leave to an expert.
    None the less it may not be an issue and just subjective. Wind passing over the mirror can make a noise. Windshield could be leaking air, could be noise from the fender or dash.
    Good luck.
  4. Fjc32
    Fjc32 New Member
    OC
    My Eco has air noise coming from driver window too. My old 13 did not have air noise like that.
  5. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Try placing a rag near the front quarter glass when you hear the noise.
    Wind noise appears to oriignate from that area.
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Buy TOYO TIRES. You won't hear any other noise but them! :ROFLMAO:
    (Yeah, I know. That joke is getting stale.)
