Driving in a deep puddle or flooded streets...
Discussion in 'Gen 3 Prius Main Forum' started by prinut, Jun 19, 2013.
  1. prinut
    prinut Pri Nut
    102
    23
    SouthFlorida
    Does anyone have any info/suggestions or concerns for driving in a deep puddle?
    What are the risks involved and how deep a puddle can the Prius wade through?
    Is there a higher risk of electrical shortage?
    That's one of my big concerns since in SoFL, when it rains, it can sometimes pour and cause local flooding!!
    Thoughts?
  2. WE0H
    WE0H Senior Member
    3,247
    528
    I wouldn't go in anything deeper than the floorpan. Prius no doubt has waterproof connectors but...
    Mike :)
    Mobile on my SGH-i717
    51,155
    that's what my 'inclement weather vehicle' is for.;)
    WE0H likes this.
  4. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    There's a lot of things that can go wrong. The HV system's connectors are high enough up that they won't be affected, as far as I know (from the battery to the inverter, both of which are fairly high up - not sure where the connection from the inverter to the MG is, though). But, like any other car, you can get water into the air intake, or other wiring at the floor level (like for the airbags) that will cost many thousands of dollars to fix. The ground clearance is only about 5-6 inches.
    The best thing you can do is turn around and find a different route.
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've been trapped by rising flood waters with no way to return. I waited until another car came watched how high the water reached on it and followed. The water was up to the top of the door sills on the Prius but no water came in and we got through without problems. I really didn't want to be stuck between the two flood events as I knew that that whole flood plain can go under. We were 60 Kms from the nearest town.
    I hope to never repeat that experience, but who can predict freak weather?
  6. Jzerocsk
    Jzerocsk Member
    108
    31
  7. El Dobro
    El Dobro A Member
    7,075
    3,258
    I think this would be excessive for a Prius.
    Blu-ray and retired4999 like this.
