Driving in a flood
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Jun 19, 2018.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I drove my gen3 prius in a flood recently and I when I went thru a low spot in the flood i clearly heard water rushing in and bubling in somewhere. Now when the engine is off and I brake hard I can clearly hear water somewhere in the back seat area slooshing around. Where could that water be? It sounds like a lot of water
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Having not been there, I hope the situation warranted it. A Prius and driving through a flooded area just don't go together, but situations happen. Glad to hear it's still driving normally, just water logged. Are your floorboards wet? If not, I would suspect the water is in the trunk area on the outside edges and maybe even in the spare tire well. The outer edges of your trunk have vents in them. The vents are typically just lightweight rubber flaps designed to allow air flow to go only one direction, but there's no guarantee how they would handle water.
  3. TrackTravis
    TrackTravis Junior Member
    Tampa, Florida
    Thanks for the tips, TMR-JWAP! Will keep these in mind.
  4. franken1313
    franken1313 Member
    216
    27
    US
    The spare tire and floors are dry. I suspect it's underneath the floor board. How do I get under the floor boards?
  5. bisco
    52,009
    are the carpets dry? check the battery case, pull the orange safety plug first!:eek:
  6. franken1313
    franken1313 Member
    216
    27
    US
    Yes carpet is dry
  7. orenji
    orenji Senior Member
    5,887
    3,488
    We're the carpets ever wet? You sure your not hearing gas in the fuel tank?
    #7 orenji, Jun 21, 2018
  8. franken1313
    franken1313 Member
    216
    27
    US
    I've definitely never heard this water noise before. If the carpets were wet where could the pool of water be?
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Might be in the big box the HV battery is in?????? I'd take it to somebody who's really up on the Prius.
  10. Elektroingenieur
    2,515
    3,284
    Three Touring
    Also see Toyota service bulletin T-SB-0229-12 Rev1, “Flood Damaged Vehicle Inspection and Handling,” revised November 22, 2017. The bulletin is available by subscription to techinfo.toyota.com; someone posted an earlier revision (PDF) on PriusChat.
