Driving in "B"
Discussion in 'Gen 3 Prius Main Forum' started by priforme, Apr 30, 2012.
  1. priforme
    priforme Junior Member
    22
    So FL
    Driving along I noticed that my EV and ECO indicators were off. It turn about that my wife inadvertently put the car "B" while playing with the radio. I must have been driving like that for about 10 minutes doing no more than 40-45 on a flat road. Do you think any damage was done?
    iPhone ?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Nope
    Driving it for 10,000 miles in B is unlikely to cause any damage I wouldn't have though either.
    She's not the only one doing that though. I often use B coming down a steep hill and forget to select Drive when I reach the bottom.
  3. daniel
    14,487
    1,519
    Spokane, WA
    No harm done at all. It's a little bit less efficient except where intended. (Long, steep downhills when the battery is too full for regen.) Maybe you burned an extra quarter of a teaspoon of gas.
    Welcome to Prius Chat, and enjoy the car!
  4. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I was on a long drive the other day (highway) and on a very long downhill I put it in B so as not to speed up any more then I already was speeding.... forgot to put it back in D. I didn't notice until I couldn't get the Cruise Control to Set. I probably did less then a mile that way but I thought it was interesting that CC won't work in B mode.
  5. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Used the B mode this past weekend on a road trip from Reston Va to Berryviille Va on Rt7... Some steep declines, and I still showed 100 mpg using the engine breaking of the B mode...
    I use to use the B mode on my commute on a downhill grade, till I learned that breaking as usual worked as well...
    My take is leaving the B mode on longer than needed is that the ICE runs more than needed...
  6. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    It shouldn't cause any problem whatsoever, since it only ever tries to actually engine break when you let off the gas. I think it's designed to be able to be left in B indefinitely with no damage to the car.
  7. priforme
    22
    So FL
    Thanks everyone! One of these days I'll stop babying my car ☺
    iPhone ?
  8. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    No problem, think we all do it with any new car - but with the Prius and lack of the standard auto transmission and and it's intelligence we are all newbies....
  9. fuzzy1
    10,653
    It needlessly blew 5 to 10 cents of fuel money out of your wallet. Anything else was comparatively minor.
  10. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    For some topics [when discussing a Prius] it might be more appropriate to speak of fuel consumption in terms of CCs [Cubic Centimeter]. A teaspoon being roughly 10CC.
    Perhaps it is more accurate to picture this kind of 'wastefulness' as burning as extra CC.
    A gallon has 3,785CCs. At $3.50/gallon a single CC rounds to like 1/10 of a cent.
