Driving in Eco Mode, Starting From A Stop
Discussion in 'Gen 3 Prius Fuel Economy' started by Crankykentucky, Aug 31, 2010.
  1. Crankykentucky
    Crankykentucky Junior Member
    65
    Midwest
    Ok, I'm starting to dig my Prius III and I want to "keep" the trial version of sat radio, but my wife just looks at me and points to my CD collection.
    So, seriously, what is the best way to start off from a stop light with a Prius? I've seen people clearly just punch it off of the line, but their has to be a way to keep the little MPG meter on the dash from plunging when I start out from a stop.
    Do a lot of you leave your Prius in "Power" mode around town or Eco mode?
    I'm catching some ribbing from my friends over my Prius. But, I think I made a wise choice. I couldn't fit my mountain bike in my Beetle Convertible unless I put the top down. But, the Prius takes the bike with no sweat.
    Thanks in advance,
    Fred
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You will get a lot of varying opinions on this. So, I will give you mine :)
    I tried all three modes and settled for Normal mode, no mode lights on the dash. The only difference in the modes is the mapping of the accelerator pedal movement for the first one-half of travel. In Eco you just have to move the pedal further for the same acceleration in the other modes. Power gives you more acceleration for much less pedal movement. Normal is in the middle of these two.
    As for starting from a stop, I have found that if I accelerate with the HSI monitor pushing hard in the PWR range on the right hand side that lets me get up to speed quicker. Then I can either coast or glide quicker once I get up to speed and that seems to help my overall mpg.
  3. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    Brisk acceleration is my choice. That's hitting 3500 RPM briefly, just enough to get up to speed at a slightly faster than normal rate.
    I strongly believe in the JUST DRIVE IT motto and don't mind being in the PWR zone on the eco-meter at times. The system takes advantage of the engine when you do that. It generates a little electricity as a result. So, you don't see the overall benefit right away.
  4. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    Acceleration will dramatically reduce impg. Sad fact of physics. Some go a little faster than others to get it over with. Short low mpg acceleration or longer not quite as low mpg acceleration (me, usually) makes less difference than learning to conserve the kinetic energy of the vehicle once the acceleration ends. In town, this often involves gliding.
    You certainly want to stay below the point at which the battery helps the ICE. I think optimal mpg comes by using battery off the line, then the ICE kicks in at 10 or 15 mph where it starts to have some torque.
    In the gen3, I generally accelerate just below the PWR section of the HSI, sometimes well into PWR, until I near target top speed. Then I'll either P&G or hold a pretty even speed depending on the situation. I use ECO mode all the time so I can better hold a glide.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Assuming a clear road ahead with no additional stops, you want to accelerate to your cruising speed with the least amount of energy. Accelerating slowly minimizes the instantaneous use of energy, but uses it over a long time. Accelerating at full throttle minimizes the amount of time that you are accelerating, but does so at a very inefficient engine setting. Someplace in between is the sweet spot. Speaking in general terms, the sweet spot comes from brisk acceleration, but still well away from full throttle. Try to avoid drawing from the HV battery, and try to avoid wide open throttle.
    Tom
  6. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I don't mean to go off topic, but I wondered what it meant when no lights were shown on the dash. Couldn't find it quickly in the manual (not that I tried that hard).
    I thought there was only EV mode, ECO mode and Power mode. Duh!
    Dumb Mike
  7. fuzzy1
    10,254
    deleted
  8. vahrn
    vahrn New Member
    66
    Parma, Italy
    If you press the PWR a green light will appear on the dashboard, if you press the ECO button another light also green but different will appear. If you press once or twice either PWR o ECO (depending on which mode is active at that time) no green light will be active. This is the Normal mode, which is something between PWR and ECO. ECO is particularly useful if you turn A/C on (since it lowers A/C power consumption) and if want to hold a glide as makes throttle less sensitive to foot movement, PWR is nice if you want to drive aggressively or uphill.
  9. almypal26
    almypal26 Member
    101
    So Cal
    So what is better? ECO or Normal mode. I've always driven in ECO and rarely in PWR. Thanks for the explanation.:eek:
  10. qbee42
    18,058
    3,074
    Northern Michigan
    One isn't better than the other. It depends on your tastes and needs. Full power is available in all modes, although ECO will downplay the use of AC and heat, which can help with your mileage.
    Tom
  11. DumbMike
    560
    119
    Los Angeles
    I really appreciate the information. I didn't think this was something that was explained very well in the manual. Plus, I couldn't figure out why the ECO or PWR light would go off when I pushed the button a second time. An in-between mode! Go figure.
    Maybe next time/generation, Toyota will have a "gradation" switch in which you set it between 1 to 10, where 1 is ECO mode and 10 is PWR mode and you get all of the gradations in-between. But not sure whether it's worth it.
    Dumb Mike
  12. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    I love this idea! It'll save Toyota money too cause all they need is a rotary dial like the radio volume, or another sliding lever besides the gear knob. You push forward for PWR and pull back for ECO. Yeah, this is better than a rotary dial. That makes it very futuristic and high tech like an airplane!
    I want this in MY25 Toyota! (That's my target year for retiring the current and getting a new Prius.):D
