Driving in HV only long term
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MikePIP, Oct 22, 2014.
  1. MikePIP
    MikePIP New Member
    17
    Bay Area, CA
    2014 Prius Plug-in
    Hi All,
    I just purchased a new PIP Advanced in Pearl White. I'm currently living in an condo complex that does not have a charging station so I am only driving the car in HV mode and leaving the traction battery depleted. Is this bad for the traction battery in the long run?
    49,409
    welcome and congrats! no prolemo, actually better for it to have a low charge than i high one, according to toyota. search around for free charging like whole foods, costco, and etc., all the best!(y)
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    Dear new Prius owner:
    Fear not, the battery will never be depleted. The system will ensure that it maintains a safe charge on the main traction battery at all times.
  4. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    This may or may not apply to you, but I use a standard outlet in the garage to charge my PIP.
  5. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Depleted = no plug-supplied electricity remaining.
    That's means there is as much as 23.5% of the battery's total capacity still available.
    HV mode operates between that 23.5% and roughly 18%. So, even without ever plugging in, the pack will be just fine.
