Driving Modes..
Discussion in 'Newbie Forum' started by nanoxnano, May 5, 2015.
  1. nanoxnano
    nanoxnano Junior Member
    26
    Does it really matter which driver mode you choose (Eco or OFF) as long as you drive strategically to achieve the greatest gas mileage? I am tempted to turn them all OFF but then again I do want that extra 1 mpg or more if it makes a difference to turn on ECO mode.
  2. fuzzy1
    10,603
    Use whatever mode works best for you, different drivers get different results. Those buttons change only the user interface at the gas pedal, not anything within the propulsion system. (Well, except for allowing some more slop in cruise control and air conditioning operation. When you are trying to achieve top mpg, you probably have both of those turned off.)
    Those of us who are a bit clumsy, but patient, are most likely to do best in ECO. Better coordinated but less patient drivers may overcompensate for ECO's filtering and delays, and do better in Normal or PWR.
    In theory, the very same mpg should be achievable in all three modes. But only drivers lacking common human frailties are likely to see this.
    Many drivers don't see enough mpg difference to bother overriding a choice based on preferred touch and feel.
    #2 fuzzy1, May 5, 2015
    gsmckee and nanoxnano like this.
