driving on bad hybrid battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by boscohoney, Jan 4, 2016.
  1. boscohoney
    boscohoney Junior Member
    16
    Urbandale, Iowa
    DTC P0A80 but still driving although battery read out flucuates. How lon gcan this battery last before it totally quits?
  2. JC91006
    16,672
    8,518
    are you still under warranty?
  3. boscohoney
    16
    Urbandale, Iowa
    no this is in a 2005 prius with 110000 miles, thanks for your concern
    51,144
    probably quite awhile, they don't usually just die.
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Buy a MiniVCI and install on your Win32 laptop, and you'll see exactly what the problem is.
  6. boscohoney
    16
    Urbandale, Iowa
    where
    ( sorry ) where can i purchase this item? Thank You
    #6 boscohoney, Jan 4, 2016
  7. bisco
    51,144
    ebay. usually, an old laptop is recommended, due to virus.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    I have seen plenty of customers get stranded when driving on a P0A80.
    It's hard to quantify what exactly pushes the battery past the point of no return. Can be when it is cold. Or when it is hot. Or using EV heavily (like when backing up a hill). A high load situation.
    I can say that a Prius with P0A80 is no longer reliable. You might be OK one day, but get stranded the next. Have a backup plan ready, even if that means simply keeping a cell phone handy.
    Dino33ca and uart like this.
  9. boscohoney
    16
    Urbandale, Iowa
    I am planniong on changing the battery (not 12 volt) ON 2005 PRIUS WITH A BATTERY FROM NAPA $1389.00 FOR THE BATTERY WITH 3 YEAR WARRANTY . HAS ANYONE HAD ANY EXPERIENCE WITH NAPA. I WORK ON CARS SO SHOULD NOT HAVE ANY PROBLEM DOING THIS. ONLY ONE QUESTION REGARDING CLEARING THE CODE OFF WILL IT CLEAR ITS SELF AFTER THE NEW BATTERY IS INSTALLED? THANKS FOR ANY INFORMATION REGARDING ANY PROBLEMS I MIGHT ENCOUNTER.
  10. bisco
    51,144
    napa/dorman is about as good as it gets in the rebuilt world. some people have had issues with defects and warranty, but much better than anywhere else afaik.
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Contacting a dealer & Toyota asking if they can help you on the replacement may get a goodwill discount. Doesn't hurt to ask.
  12. boscohoney
    16
    Urbandale, Iowa
    TRYED, THAT NO SUCH LUCK
  13. bisco
    51,144
    ouch, my ears.:p
    yeah, 3 years and 30,000 miles outside the warranty is probably a stretch.
  14. boscohoney
    16
    Urbandale, Iowa
    CAN'T HURT TO TRY
  15. strawbrad
    953
    1,002
    My offer still stands. Rebuilt, $800 installed with a one year warranty.
    Brad
    S Keith likes this.
  16. bisco
    51,144
    GREAT DEAL!
  17. JasonATX
    JasonATX Junior Member
    When my original battery threw codes for the first time it only drove for about 10 miles before going into the limp home mode where the HV battery isolates itself (no charging or discharging), the engine runs at high RPM all the time and you accelerate at a snails pace (like about 30 seconds to get to 30MPH). Clearing the codes or stopping/restarting the car resulted in it driving maybe another minute or two before the process started again.
    However, when I pulled the battery stats after getting it back home I found the bad module was only putting out ~5v compared to the others doing normal voltages so that module had a serious fault. Depending on the severity of the underlying issue you may can drive it for weeks or months. But you'll always be taking a risk.
    It may be that the worst that can happen is you get stuck in limp home like me. If you don't go on long trips or are ok with towing it home, you may be ok trying to milk every last mile out of it. Mine died 800 miles from home so I had to rent a Uhaul and car carrier to bring it back.
    #17 JasonATX, Jan 7, 2016
