Driving Style Changes
Discussion in 'Gen 2 Prius Main Forum' started by cjoshuav, Feb 6, 2008.
  1. cjoshuav
    cjoshuav New Member
    17
    I'm used to driving a fairly sporty car (Subaru Legacy GT) that's overall wasted in-town but a lot of fun on curvy mountain roads and even just cruising on the interstate.
    I'm not typically an aggressive driver, but living in a big city (Atlanta) I'm used to having to accelerate quickly sometimes to grab a spot in a lane and such.
    I'm committed to buying a Prius once I get the right deal, and I've been happy with my test driving experiences. I realize, however, that a test drive is not the same thing as a road trip or a week of commuting.
    Any thoughts on how my driving experience is going to change once I'm in a Prius and trying to be sensible about my MPG? How will the Prius handle my usually road-trip average cruising speed of 78 MPH?
    Thanks for your thoughts.
    -Joshua
  2. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Don't cruise at 78, you will feel the hit in the mpg. Stick to 65. You can rent one for a few days from a Toyota dealer to make sure you like it first. A bit of money to spend, but if it saves you $20,000 if you don't like the car, it is money well spent. If you want more oompf but still good (just not stellar) mileage, try the Camry Hybrid.
    Fernsmom:)
  3. cjoshuav
    cjoshuav New Member
    17
    Eep! I fear 65 on a road trip would drive me insane. How much of a hit will I take in MPG? I might be better off just renting a car when I'm going out-of-state.
    While I was doing my Ph.D. coursework I had to commute from Atlanta to Nashville and back, sometimes in the same day. That's why I had a nice, sturdy Subaru. The Prius looks appealing because most of my driving is in-town now, so it's not as big of a concern.
    Joshua
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Cjoshuav,
    While the Prius is not a sporty car, and does not have the HP specification of many cars. But these cars have old fashioned technology transmissions which do not allow the engine to reach the HP specification at low vehicles speeds. It takes 6 or more gears to get the engine match to the car that the Prius transmission provides. Then the problem is shift time with that many gears. The solution is then DSG transmissions. Right now there are very few cars on the road with 6 or 7 speed DSG transmissions, so in traffic, you will have no problem with the Prius.
    The Prius should double your 78 mph mileage you are getting in the Legacy in the summertime. I am guessing that the Legacy gets about 18 mpg (as the old EPA on these cars was about 22 mpg if memory serves) at 78 mpg. The Prius will be around the 40 mpg at these speeds. Better downwind, downhill, and worse uphill, upwind. It will have no problem cruising at this speed.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius will cruise just fine at your accustomed 78 mph. We find we have a hard time keeping the speed down, since the Prius cruises with so little fuss and bother. At any speed you will do much better than any other car you have every driven. What the other posters are hinting at is that the Prius tends to get into the very core of your soul and brings about a change in driving behaviour. It's not that you need to slow down, but you get so engrossed in mileage that you want to slow down. I drive the speed limit, unless the weather is bad. I could drive faster, but I don't feel the need.
    Tom
  6. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I think the question is why are you committed to buying the Prius? If you want to maximize mpg no matter what, then you would want to alter your driving style and slow down on the highway. If you want better mpg than you'd get with pretty much any other vehicle that uses gasoline, get a Prius and drive it 78 mph on the highway. It's perfectly capable of going that speed, even though it's not ideal for gas mileage.
    When I drive between DC and Long Island my speed varies from 65 - 75 mph, depending on which highway I'm on, what the speed limit is and what mood I'm in. Over the summer I was averaging a bit over 50 mpg on these trips. Since winter temps kicked in I am driving a little slower (65 - 68 mph) to offset the effect of colder weather and am getting around 49-50 mpg.
    As for acceleration, I haven't had any problems with city driving. The Prius isn't the fastest 0-60 car on the market, for but 0-25 or 30 it's fine.
    p.s. For some folks, getting the Prius makes them want to slow down a bit on the highway because maximizing gas mileage becomes something of a game, with the car giving you real-time feedback on how you're doing. So you might decide that driving 65 (or maybe 70) doesn't make you crazy after all.
  7. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    When I travel between St. George, Utah in the southwest corner of the state to Salt Lake City -- just over 300 miles on I-15, I usually set the cruise control to 78 mph most of the way and let the car do its thing. Under those conditions, I usually average around 47 mpg. When I travel between St. George and Santa Fe, New Mexico, I travel mostly two-lane state highways and have the cruise control set around 68 mph for most of that 600-mile trip. Under those conditions, I average around 52 mpg.
    I find the Prius comfortable and I like the handling both on hilly interstates and on the winding mountainous roads in the area. But then, some folks have complaints so I guess its pretty subjective.
  8. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I just traded in my 2004 Volvo S60R, 300hp, AWD for a 2008 Touring Prius. My driving habits have changed tremendously. Mostly, I find myself staring at the energy & consumption screen. It is almost like a video game trying to keep the ICE from turning on. Needless to say, I drive a lot slower now.
    I will admit that it is a far cry from the S60R in acceleration, but when needed to get up and go, I haven't had an experience where I couldn't do what I needed Prius to do.
    The one thing you need to becareful with is cornering. I had 235/40 18" Michelin Pilot Sport 2's on the R, so I had to make a mental adjustment before I got myself in trouble with the Prius. Even with the touring suspension, it tends to lean a little more than I am used to. Especially when going from a left hander to a right hander.
  9. artie
    artie Member
    231
    65
    san diego
    I've always been an overly fast, aggressive driver just because i like to go fast and first. I know, sorry. Anyway, as mentioned above, after buying the Prius 4 years ago I now get the same fun, honest, in maximizing mpg. The car has totally changed my driving behavior. And when I care to, I also will cruise at 80, getting around 44 to 46 mpg, sometimes a bit less, and that's just fine.
    I took the car in for service, the store lent me a BMW, last month. Got a speeding ticket, 93. Luckily I was able to do the school, and I'm glad to be back in the Prius.
  10. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    It has been a whole new experience driving on the right side of L.A. freeways, now that I have been driving closer to the speed limit. It's like a different world!
  11. artie
    artie Member
    231
    65
    san diego
    I'd like to add to my post above re 93 mph ticket in the loaner bmw, the CHP officer didn't say a thing to me, took my license, came back to the car, and said he wrote me up for 70, 5 miles over. He had previously showed me his speed gun with 93 in neon numbers. So I got a break, and boy, did I thank him! I didn't mention to him that he caught me as I was slowing down to exit the f-way...I had the beemer up to 115 a little way back. So, I learned my lesson, luckily hurt no one, and am glad to be back in my safe wonderful Prius, driving sanely and peacefully.
  12. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    I've slowed down since buying my Prius just 1 1/2 months ago. I took a 2600 mile road-trip and cruised at the speed limit on I90 & I94 which was either 70 or 75, depending on the state I happened to be in. Mileage was better when I slowed down. I also had some pretty stiff wind, both head wind and tail wind as well as some cross-wind, and that all has a fairly pronounced effect. But I find that I just prefer to drive slower now. Funny, that.....:)
  13. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    eh, i still drive 80 on the highway. higher depending on conditions.
    the car does fine, just watch how you take the curves on the oem tires.
  14. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    i seem to remember a thread about a year ago about what people listgend to in their prius...... i remember it got all Zen ...... i dont need to be mediating in my car
  15. patsparks
    10,664
    567
    Adelaide South Australia
    The Prius is about better fuel consumption without making compromises. Drive at 78mph if you want just make sure you don't expect EPA MPG but you will get better than the Subaru. Accelerating reasonably briskly has a smaller affect on MPG than people think, I believe the biggest gains are to be found in coasting to a stop and avoiding hard braking. At about 78MPH you will still get good consumption compared to anything but maybe a small diesel like Polo or Golf but your ride will be quieter and more comfortable.
    Do it.
