Driving the Prius Around Close to the Ocean
Discussion in 'Newbie Forum' started by Mikawa, Jul 5, 2012.
  1. Mikawa
    Mikawa Junior Member
    32
    Rancho Palos Verdes, Southern California
    Hello, I'm new here from Southern California, just got the car two weeks ago. I live about a mile from the ocean. I had vaguely heard that driving around close to the ocean most of the time - with the salty sea air - is not really good for the car corrosion-wise. Any take on this?
    I live and work somewhat close to the ocean, so my commute pretty much isn't far away from the coast. Even my kids' preschool is walking distance from the surf (Pacific Coast Highway). If it is bad what precautions should I take?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I also live/commute close to sea water. I heard most places in Japan are also "close" to sea water. I don't think you have a thing to worry about.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Anything close to the ocean will suffer from accelerated corrosion - the Prius is no exception. It's nothing to worry about, but it is part of the price you pay for living near the water.
    Tom
  4. Mikawa
    32
    That is true. Plus Japan also has the monsoons.
  5. bisco
    51,155
    it's not nearly as bad as road salt.
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    OMG I am close to (surrounded by) the ocean also.... I am not worried about it though.
    Posted from my iPhone via the Tapatalk app.
  7. bisco
    51,155
    i am close to the ocean and have road salt. haven't seen any serious corrosion since my 72 fiat.
  8. JamesCSmith
    JamesCSmith New Member
    59
    Look around you at all the cars on the road. They all drive close to the ocean and most of them look great even when they are old gen 1 models on the road more many years.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    Winter driving is much worse, in states like mine where we use salt.
    Sea air varies. In some locations you get spray, which will definitely cause problems. Other locations have a lot of moisture, which isn't as bad as salt spray, but it does induce rust. A lot of California is essentially desert, even fairly close to the ocean. In these locations the ocean isn't going to matter, unless you drive on the beach.
    Tom
