Driving through flooded street: EV or Gas mode?
Discussion in 'Gen 3 Prius Technical Discussion' started by Terrell, Aug 22, 2018.
  1. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    OK, I know, never drive through a flooded street, because 1) you don't know how deep the water is, and 2) you don't know whether the roadway under the water is still there, it may have been washed away. Turn around, don't drown.
    Now that that's said, there's been much flooding around the US, and recently, also here in Wisconsin.
    Cars that plow into water on streets usually die, because of water entering the air intake of the engine, I believe. Then you're stuck. (Which is why it's really stupid to try to go through water fast - it doesn't split the water like Moses, it floods the engine faster!)
    Now my question: What about switching to EV mode (electric only). Now you're using only the electric engine. Would you be able to go through deeper water in EV mode than in normal mode with the gasoline engine? (Assuming you don't lose contact with the road by floating, or get swept away by the current.)
    And yes, I realize driving through deep water ruins the whole car. But let's just ask the question: Gas or Electric? Which will get you further in a flood? Will everything short out? Or keep you going? (No, don't try this!)
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I guess it will make some difference as there will not be any air (and water) sucked into the airfilter, but still, if the water gets as high as your airfilter (but then you're really nice person-deep in water ;) ) it will be likely to seep into the engine. The airfilter itself is a bit of a block of course, no idea how much it will hold off water.
  3. worrachai
    worrachai Junior Member
    48
    thailand
    In my country(Thailand). Many time was flooded on the main road. 1 time, I drove on the flood high 12" from the floor but continue running with normal mode. It's OK no everything happen.
    By the way, most of driver knew that running on the flood road should not use the air-conditioner.
    51,669
    if the water is high enough to reach the air intake, the battery likely will have exploded by then.
    my answer: it won't matter.
  5. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    The battery internal packs are wired by the pairs, it won't explode. Imagine a flashlight with a lot of D batteries wired in series (lined up) like a 1000 of them. If water gets in, each battery will ground itself and not even explode let alone put out a charge.
  6. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    That might be the case with lithium batteries, but the 2010 uses NiMH batteries, so I doubt that it would explode. Maybe short out, though.
  7. Tideland Prius
    16,529
    Well if it's high enough to reach the engine air intake, it's too deep lol.
    The exhaust pipe would be what I'm worried about so if I were in that situation, I would be running in hybrid mode in "B" to keep the gas engine running and reduce the amount of water entering via the exhaust pipe (and potentially damaging the catalytic converter).
  8. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Wouldn't forward motion keep most water out of the exhaust pipe? If the water is deeper than the pipe, and you're standing still, it will get in. But some water (vapor) gets into the catalytic converter from the engine running normally, and it's the heat that keeps it from pooling up in there, right? Water in the exhaust system is what causes it to eventually rust out. So I wouldn't think getting water in the exhaust pipe would ruin the catalytic converter, but maybe I'm wrong.
    #8 Terrell, Aug 28, 2018
    Tideland Prius likes this.
  9. fuzzy1
    10,356
    Water condensation in exhaust ought to be much cleaner (from the catalyst perspective, at least) than floodwater.
  10. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Doesn't the water come into the car, ruining the carpets? And what keeps the car from floating if the water is 12" deep?
    True, floodwater is not at all clean. There were kids playing in the flooded streets and people riding bikes into the water, without realizing the floodwater was contaminated by sewage (the sewers were backing up).
  11. Tideland Prius
    16,529
    Depends how deep the water is. You have to be extremely careful and keep that constant speed (as you know, because you were talking about the wave ahead of the car).
  12. fuzzy1
    10,356
    The sewage component should be quite thin, very dilute, negligible to the catalyst. But the mud component can be quite heavy.
  13. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I drove very slowly through some water that was perhaps to the bottom of the doors after watching other cars go through, so I knew the pavement was still there. I drove very slowly, so water would not splash up into the engine. I drove around three cars ahead of me that had their emergency flashers on and were stopped. I don't know why, perhaps they tried to speed through the water. There were other times when I turned around and tried other ways to get home. One car ahead of me plowed into water halfway up his doors, and there he sat. Or, there he bobbed - for a while. We had some flash flooding Aug 20.
  14. bisco
    51,669
    maybe start with toyota's thesis on how to repair a flood car, and work backwards from there.
  15. Tideland Prius
    16,529
    In your case, either mode is fine but you could stay in EV mode if you're worried about the wake from other vehicles accidentally splashing the engine area.
  16. working1
    working1 Active Member
    121
    112
    I got caught up in the Wisconsin rain on the way home Tuesday with my Prius. Interstate was closed so I made a really bad decision and tried taking a country back road. The next hour was an adventure with at least 10 crossings over flooded roads with moving water, blinding rain, high winds, down trees and a tornado warning. I made it out, but, it could have turned out much differently. Had visions of being featured on the weather channel as an example of what not to do.
    However, the Prius had no issues with these crossings with some of them above the door sill. I kept the car moving at a slow speed. Maybe 5 mph. The Bridgestone SERENITY+ tires felt solid with no indication of hydroplaning. I never thought about keeping it in EV mode, but, odds are it was running in EV mode automatically with the slow speed.
    I've drove more than 300 miles since then without an issue. I'm rotating tires/changing oil this weekend and will inspect for any damage. More worried about running over the tree branches than driving through the water.
  17. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Wow! Are you in Sauk? I was also driving Tuesday, saw some water on the roads, but no flooding (Madison). Make sure your carpets didn't get wet, they might mold. Yes, running over tree branches, which could be hidden under the water, can be a problem.
    I damaged the front splash panel on a parking curb, and the oil change door fell off when the insulation got wet and became too heavy for the panel (because not all the screws got put back in correctly at my last oil change, and no, I didn't do it, the dealer did.) So I had it dragging under the car while I was driving, had to stop to stuff it back up and the next day had the dealer replace the whole front splash panel. It was not cheap!
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    That’s so stupid.
