Driving with red triangle of death / bad battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wolfgang97, Aug 8, 2021.
  1. Wolfgang97
    Wolfgang97 New Member
    Seattle
    Hi all, I’ve owned my 09 Prius for a few months and after 10k miles just got the red triangle of death with codes p0a80 and p3000 @ 187k. I bought it for a fair price knowing the traction battery may need replacing in the near future. I’ve been considering my options and seeing as I’m a broke student and only looking to drive the Prius through the rest of this summer I’m considering just having the bad module(s) replaced and the pack rebalanced as a short term fix until I find the 4Runner I’m looking for.. My question is:
    Can I reset the p0a80 code and drive it 20 miles to the shop without inflicting more damage or will I need it to be towed?
    Thanks,
    James
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,963
    4,709
    Texas Hill Country
    If it will drive now just drive it to the shop. Otherwise clear the codes.
  3. JC91006
    16,481
    8,397
    Op - "I'm a broke student"
    Also Op - Waiting to find the right 4Runner LOL
    If the car has the replace hybrid battery code, then you can try and swap out all the weak/failed modules, then balance the pack. That should be good enough to last a while until you can find your 4runner (gas guzzler, not for broke students)
    SFO and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    A 98 4runner with a diff locker may have met the criteria;).
    Too bad I do t have one of those anymore(y).
  5. JC91006
    16,481
    8,397
    That’s worth $10k plus now
    Raytheeagle likes this.
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Crazy world we live in:whistle:.
    I had a friend out here from TX who has a 2018 GMC Sierra HD and he said it is worth more now than when he bought it new:eek:.
    Was gonna do a direct swap for a new Corvette until he looked in the interior :cool:.
    May have talked him into a Model S:).
    The center console makes the flying bridge of the Gen3 Prius palatable(y).
    JC91006 likes this.
  7. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Not that far south from you, see if @PriusCamper can sort you out. Most likely a better option than your mechanic.
    Raytheeagle and JC91006 like this.
  8. BuildingInspectorBrian
    BuildingInspectorBrian Junior Member
    32
    Tacoma
    You won't likely inflict more damage driving it 20 miles to the shop, you will however have to reset the codes multiple times. If you have an obd capable of resetting the codes while driving it can get you there, limp mode sucks but it shouldn't leave you stranded.
    Having the bad modules replaced and rebalancing the pack can be a good short term solution. A new or aftermarket traction battery is $1,600-$2,200 and will last you 10+ years and cost you a fraction of what a 4 runner will (use the gas savings of driving the Prius to buy the 4 runner, lol).
