DRL advice on my new 2010 Prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by doublesman, Oct 31, 2011.
  1. doublesman
    doublesman Junior Member
    Toronto
    I just bought a used 2010 prius with < 10K miles , exporting it to Toronto . Excited :). However first order of business is to add DRL to the car without getting shafted by a dealer to do it. I would do it while driving it in the States if anyone knows someone able to handle the wiring in this car.
    I would be driving through Ohio , Pennsylvania and NY towards buffalo.
    ALso would anyone know if I can use the one from juicedhybrid d0tcom
    It must be on with car ignition . The diagram or explanation on these seem overly simplistic when compared to a module which I found elsewhere on this forum but used in Prius models < 2010.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I doubt that any glue on LED strips would meet the DRL requirements. Just not bright enough.
  3. blaqdragun
    blaqdragun New Member
    Clifton
    Just to confirm, did you order the DRL-2P module? It is listed as only working on 2004-2009 Gen II models. Are the instructions different when installing on a Gen III? Thank you.
  4. lpe350
    lpe350 Member
    56
    32
    Long Island
    Why not install the fog light kit and use an accessory lead to turn them on while the car is on using a relay. If you bypass the switch, it should serve your purpose.
  5. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Fog lights have a standard 55W bulbs, so same consumption and bulb's life shortage. DRL have to be LED based, the LEDs affect MPG as well.
