DRL lights at tail.
Discussion in 'Prius v Technical Discussion' started by Sfpep, Oct 18, 2020.
Tags:
  1. Sfpep
    Sfpep New Member
    Finland
    2016 Prius+ MPV
    Hi! I hope this is the right place to ask this. I have 2016 prius+ and i have come across only one negative thing in these past two years. When I have the lights on "auto" mode and daytime its running on the DRL lights and all tail lights are off. Is it programmable or do i have to search some relays to get the tail lights on also on daytime?
    Thanks..
  2. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Just turn on your marker lights. But why?
    Minima Domum and fuzzy1 like this.
  3. fuzzy1
    10,602
    That is the definition of DRLs -- two front lamps only, no side or tail lights.
  4. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    I haven't seen that setting on Carista but using the headlight switch on the city light position on mine, turns on the DRL and the rear tail.
    Tyfly likes this.
  5. Sfpep
    Sfpep New Member
    Finland
    2016 Prius+ MPV
    Yeah i know how they work... I was just wondering that is it possible to program tail lights to come on ALSO with the DRL lights on front. Here in Finland it is allowed to drive only on DRL but i feel more secure when there is also lights in the tail. And as lazy arse as i am i would like the car do it all for me. "Light switch in auto mode."
  6. Air_Boss
    4,220
    1,188
    New Yawk
    If push came to shove you could physically wire the tails to the DRLs.
    Minima Domum likes this.
  7. Sfpep
    Sfpep New Member
    Finland
    2016 Prius+ MPV
    yep... that is the last option. Thats why im here asking if someone have done it only programming.
  8. Prodigyplace
    12,667
    11,828
    Central Virginia
    At least for Gen 4 there is a specific Customizations section in the manual that lists all the settings and whether a dealer visit is needed to change it.
  9. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    Rear DRL is a new requirement in some countries, e.g. in Canada beginning September, 2021.
    Edit: I forgot to mention that some current model year vehicles already have rear DRL but that the feature is turned off.
  10. Sfpep
    Sfpep New Member
    Finland
    2016 Prius+ MPV
    I truly hope that rear DRL is on its way to Finland too.
  11. Air_Boss
    4,220
    1,188
    New Yawk
    A single rear red drivers side position light that illuminates when front fog lights are used has been a requirement in numerous European countries (Germany, notably) for decades.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You can NOT easily do that.
    And you really don't WANT to either.
    Following drivers are somewhat less likely to notice brake lights coming on in the day time IF the tail lights are already illuminated.
    It is designed the way it is for a good reason.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    Reference please ?
    Seems like I remember that Canada does not "require" DRLs at all.
    And what models exactly are already equipped with that "feature" ??
  14. fuzzy1
    10,602
    Why don’t tail lights come on with daytime running lights? - The Globe and Mail
    "After three decades, Transport Canada finally saw the light. It was announced early last year that the rules around tail lights would change for new cars starting in 2021, ...
    Canada has required front daytime running lights (DRLs) on all vehicles sold since 1989, but it hasn’t required tail lights to come on with them."
    The new requirement actually has 3 options. Read for details. This appears geared more towards preventing "phantom cars", driving around at night with DRLs only, no taillights.
    That was fixed decades ago by the addition of CHMSL - center high mount stop light, a.k.a. "third brake light".
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    The problem was no doubt reduced some but that was NOT the initial reason for the 3rd brake light.
    A MUCH better solution would be to require automatic lights to go along with the required DRLs.
    That tends to solve ALL the perceived problems instead of trading one for another.
    Note: That's one of the few things that I HATE about my C.
    Automatic high beams but NOT automatic ON headlights.
    I have driven more than once at night with only the DRLs on.
    Tyfly likes this.
  16. fuzzy1
    10,602
    That would not be a reason to not accept the benefit.
    That is Option #2 in the article I linked above. The Canadian regulators chose to not force everyone into a single solution.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sure.
    Allowing people to be as stupid as they want is a really important concept.
    :whistle:
  18. fuzzy1
    10,602
    By imposing a new regulation, they are not allowing people to continue being as stupid as they want. But they are allowing several different solution choices, rather than dictating a single design.
  19. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Can't you just leave the lights in the "ON" position rather than the "AUTO" position? In doing so, wouldn't they then come on when the car was put into "READY", and turn off when the car is shut down?
    Minima Domum and Tyfly like this.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    NO. ON is ON.
    They would not turn on and off with the "ignition".
    Offline likes this.
