DRL power usage?
Discussion in 'Gen 3 Prius Main Forum' started by LDB, Sep 5, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Obviously there's no free lunch and no free light. How much power do the DRL's use? I see in the manual there's a DRL off setting on the headlight switch. I've also seen a thread about making the DRL stay on all the time. I liked the look of that when I saw the thread but didn't have a Prius mindset yet that every amp is golden. So now that I'm thinking gain every bit of power from anywhere it's available I'm curious how much power the DRL use and if I should trade power for the cool DRL all the time or not.
  2. lester williams
    227
    68
    mississippi
    As far as I know, the DRLs are LED and will use little power. I think they stay on in daylight when the light switch is set in ''auto''. That is where I keep mine on all our vehicles. Someone will come along with a more accurate reply.....I don't think those two small LED running lights will draw enough to make any discernible difference
  3. fuzzy1
    10,167
    You're in luck, I happen to have a replacement unit for a DRL that ate a rock.
    They are 7.2 watts each, at 12V, according to markings on the housing. When I measured it on a battery in the house, it was indeed drawing 600 mA. I didn't play with it enough to determine if it is really constant current, or if the draw increases when the supply rises to 13-14 V.
  4. Mendel Leisk
    38,720
    There is a reason for Daytime Running Lights, let's not lose track of that, lol.
    BruceInOKC likes this.
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Not all trim levels have the Auto switch position on the light stalk.
    The difference in mpg with DRLs on vs off is pretty negligible, similar to wheel covers on vs off with the oem alloy wheels.
  6. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    If they're really only about 15 watts total, that would be only a small fraction of the 1% or 1 mpg often vaguely claimed for the wheel covers.
