DRL's went out.. Help!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tshah, Mar 16, 2013.
  1. Tshah
    Tshah New Member
    So I upgraded my interior lights, parking lights and license plate lights to LED. I blew the fuse on that so I changed it to a higher wattage fuse and works great.
    However I know noticed that my DRL's aren't working. I've checked the fuse and cannot figure it out.. Can anyone help???
  2. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    I know this is a stupid question but is your car in "ready" mode and the switch in the drl position?
  3. Tshah
    Tshah New Member
    Yes.. Ive also switched modes and still nothing.
  4. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    What do you mean by switched modes?
  5. Tshah
    Tshah New Member
    Sorry... I normally have the lights on DRL.. and i went from that to Drl with parking lights and then to headlights.. switching back and forth..
  6. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    Ok and is your e-brake released?
  7. Tshah
    Tshah New Member
    ya.. e-brakes released
  8. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    Hmm ok which fuse blew and which fuses have you checked?
  9. Tshah
    Tshah New Member
    fuse 34 blew and killed the interior lights. thats been fixed. nd ive checked fuse 24and 25 both look fine.
  10. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    Is fuse 24 or 25 related to the drl system?
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The above sounds like a bad idea. The selection of fuses and their ratings for each circuit was picked for a reason and not out of a hat. Going beyond the original rating increases the possibility of wiring overheating or a fire.
    I'd switch back to a fuse w/no higher amperage rating than the original.
    Tracksyde, sfv41901 and fuzzy1 like this.
  12. Tshah
    Tshah New Member
    yes..
    24 - Headlight high beams, day time running lights and 25 DRL
  13. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    I agree...
  14. Tshah
    Tshah New Member
    Thanks for the heads up... I placed it with the same fuse now.
  15. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    Ok just to reiterate, the car must be in ready mode (ready to drive) mode in order for the drls to come on, not in 'on' state.., because they will not light up even if the ignition is just turned on...
  16. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    If you are sure that the car is started and all the fuses are good there is no reason it shouldn't be working...
  17. Tshah
    Tshah New Member
    Drls are back and working fine.. Once I replaced the fuse to the correct wattage they started working again. But now the radio is out. *(&(*&^UIHSDHFIU
  18. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
  19. fuzzy1
    10,254
    In addition to the already mentioned concern that this is a bad idea for the wiring, LEDs should be pulling less current than any incandescent lamps they replaced, so they should not be needing a larger fuse.
    ... unless you selected far brighter LEDs.
  20. Tshah
    Tshah New Member
    I'm going to remove everything tomorrow in hopes that it restores everything.
