Drop In Gas Mileage, Needing To Refuel More Often...
Discussion in 'Gen 2 Prius Fuel Economy' started by afutterman89, Jul 14, 2014.
  1. afutterman89
    afutterman89 New Member
    Concord, California
    I have a 2006 Prius with roughly 119,900 miles on it. I have noticed in recent months that I am having to refuel more often, and that my mileage has dropped to about 40 MPG, when before it was close to 45. Any ideas why this is happening?
    #1 afutterman89, Jul 14, 2014
    49,378
    welcome to priuschat! could be your 12 volt battery. but at 200k, it could be a lot of things. what major service have you done to the vehicle?
  3. afutterman89
    Concord, California
    Actually I mis-read the mileage, it's closer to 119,900, my bad.
    And as far as the service goes, it's never had the hybrid battery replaced, the other battery was replaced after a fender-bender a couple years ago, and its had the water pumps changed a couple of times. As far as I can recall it hasn't had much else done aside from routine stuff.
    49,378
    you could probably use new plugs. maybe injector cleaning, might need throttle body cleaning. check your maintenance manual for 120k service. check your oil level. start with the easy stuff.
  5. cba20k
    cba20k Junior Member
    Los Angeles, California
    I have an 08 Prius with 135k miles that has had routine maintenance done as well, and has also had the water pump replaced, and I've seen a precipitous drop in mpg in the past month from 58 to 48.
    Isn't there a link to the Toyota site that explains the service intervals? If any knows it, could you please paste below?
    Thanks!
  6. bisco
    49,378
    don't you have an owners manual?
  7. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    You can down load the owners manual as well as the service manuals from the internet.
