drop in mpg
Discussion in 'Prius c Fuel Economy' started by bitch ima prius c, May 12, 2013.
  1. bitch ima prius c
    bitch ima prius c Junior Member
    29
    LA ish
    I have had my c for 3.5 months and recently my mpg's in the city have dropped considerably. (usually I get 45-55 in town and now 20-30ish) I don't think my habits have changed, but I'm not sure it isn't operator error, either. Any thoughts?
  2. bitch ima prius c
    29
    LA ish
    thanks, sorry. I searched before I posted, but maybe not thoroughly enough
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Are all of your tires up? Have any leaked down?
  4. bitch ima prius c
    29
    LA ish
    I think they're ok. I don't have a gauge so I will go to a gas station tomorrow. It has gotten hot here, but I don't know if that would make such a difference.
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Obviously, air conditioning use will reduce mileage a little. Cooling the cabin less (with a higher target temperature) will be more economical than maintaining a colder temp.
    I don't know about the Prius c, but in the hatchback by selecting ECO mode the A/C is operated in a less demanding way.
    ChinchillaGirl likes this.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    If you want help, please answer the questionnaire.
    As for don't have a gauge, buy a quality one. Do NOT depend on notoriously inaccurate gauges on air hoses at gas stations. You have no idea what condition they're in.
    minkus and bitch ima prius c like this.
  7. bisco
    49,490
    a drop that large can't be anything minor. test your 12 volt battery. does the car seem to be running any differently? how about the behavior of the hybrid battery gauge?
  8. mahout
    mahout Active Member
    655
    116
    NC
    First, is the car in tune? spark plugs, air filters, coil packs, and timing? you need to have a diagnostic check on the car to identify any deficiencies. Most aftermarket parts stores will perform the check for free. It involves plugging a reader into the plug on your car and waiting for interrogation results.
    Tire pressures are a potential problem; make sure you have 35 psi front, 32 psig rear. And make sure you replace the air filter just in case. And its possible your oil filter is plugged if its been long time since it was replaced. Itsd small and if you've been driving in dusty areas could easily be filled with contaminants.
    First on the list of suspects is the air filter. Even a little contamination will seriously increase the pressure drop across the filter and that adds considerable effort that the engine must overcome by using more power, hence less mpg.
    And check your emergency brake to see it's releasing fully. Its a common reason for reduced mpg too. When fully released the car should easily be pushed on lecvel,ground, making sure it doesn't get away from you. If its not easy, then recheck to see the brake lever is fully off. And then if the adjustment is correct. If thats OK we get to more serious stuff: its unusual but occasionally we see a brake caliper or drum cylinder 'frozen' such that the piston or shoe is 'frozen' against the rotor or drum. Adjustment is likely not your correction unless you're a confirmed DIYer; RNR the cylinder or piston is pretty much a good mechanic's job.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    You SERIOUSLY think that there could be a problem w/the spark plugs on '13 Prius c? The spark plug change interval on my Gen 2 Prius is somewhere past 100K miles. I'm still on my original plugs after 70K miles and over 7 years. The timing can't easily be adjusted. It's all computer controlled anyway and changes all over the place (looking at IGN values on ScanGauge II) depending on MANY factors.
    Replacing an AIR filter at this point? OIL filter? OCI should be 12 months/12K miles.
    Anyway, OP will need to answer our questions.
  10. bitch ima prius c
    29
    LA ish
    - Have you read This Thead Yet? link didn't work for me
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations) I am getting aprox. 20 mpg less than I was a week ago. I can't really be more specific, sorry.
    - What fuel economy are you expecting and why?
    50-60 was not unusual a week ago
    - What are the approximate outside air temps?
    80-100 degrees
    - How long are your trips? short. 5-20 miles
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    car is a 2013
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    no to both
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? in town, 20-35 highway, for a few miles 65-70
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    flat on city streets
    - What are your tire pressures?
    unknown
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    unknown
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    04 Honda crv ex I didn't pay attention
    - What region/state are you in? (if you haven't set your location)
    ca
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    im trying to get great mpg
    - What modes are you using, if any? "normal", EV, power, eco?
    normal?
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    no
    - Are you driving using D or B mode?
    ? d
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    ac sometimes, not always
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15). factory steel wheels and whatever brand tires
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    no​
    minkus likes this.
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    This is weird... should be you are getting higher mileage with the warmer weather, not worse. Even with AC on full blast for over 50 miles, I can get better mileage on the highway than winter time.
  12. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Check to make sure that your vent in the rear driver side foot space isn't covered. This will drop MPGs significantly.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Have you trips gotten considerably shorter than before? 5 mile trips are pretty short and that'll yield a lot worse mileage than 20 mile trips, if everything else is equal.
    minkus likes this.
  14. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    You should never be getting anything near 20-30 mpg unless you're in an awful traffic jam with the AC on, are driving 100mph, make only very short trips, or drive like a complete idiot. You'd really have to try to make a normally-functioning c be that awful.
    I'd recommend taking the car back to the dealer to do a check-up. They'll be able to do a physical check-up better than we could.
    PriusCinBlack likes this.
  15. bitch ima prius c
    29
    LA ish
    thanks, everyone. car will be going in to dealer on Wednesday
    ztanos likes this.
  16. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    What are the results of your (cold) tire pressure check? And, what about the trip length change question?
  17. minkus
    369
    125
    Cleveland, OH
    Be sure to keep us updated!
  18. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Did you check the back seat vent? Another poster on here had a drastic drop because a plastic bag was covering the hole. It wouldn't let the battery engage for a significant period of time, causing awful mileage.
    minkus likes this.
  19. bitch ima prius c
    29
    LA ish
    back seat vent is clear, but I didn't know the vent was there, so I learned something!
    ztanos and minkus like this.
