Drop off in mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by BigAl61, Aug 6, 2017.
  1. BigAl61
    BigAl61 Junior Member
    El Paso
    Hello to all of you. I a 2012 Prius 3 owner, I have been getting between 52-55mpg. I recently took a 600 mile round trip and now my mileage has not gone over 46mpg. I am faithful with the routine maintenance, from Alignment, balance and rotation, oil changes and Cabin and air filter changes. This is frustrating. Anyone have any ideas as to why? Please advise! Thanks to all who take the time to provide me with any help.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Hey! Have you bought new tires lately, or been blasting the A.C full tilt? Or maybe both? How many miles on your car?
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And what SPEED were you going on that trip ?
    Faster average speed than your normal routine ??
    Extra passengers or other cargo ???
    That REALLY isn't that much of a difference.
    See what happens next.
    49,694
    how are you measuring mpg?
  5. BigAl61
    El Paso
    I had 2 other passengers and alot of extra weight on the trip. I knew that my mileage would be less. My problem is that ever since the trip my mileage has not gone back to what I was getting before the short excursion.
  6. BigAl61
    El Paso
    I use a app to record my mileage. I keep track of every mile that I drive. I only fill up, I don't just add $5 here and there. The app keeps the mileage.
  7. DavidA
    2,328
    1,812
    Chicago western burbs
    My mileage on my 2010 with 49,000 miles on it (bought July 2009) dipped very sharply the last 2 years I owned it. The most I could get from a tank was 42 in the summer and that was with a new 12v battery installed. I solved that with a Prius Prime Advanced a month ago. It only took 2 weeks to pin the MPG meter at 199.9, and it hasn't moved from that yet. Very happy so far.
  8. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    The mileage in our 2008 Prius dropped from the usual mid 40's to mid 30's one day. It lasted through three tanks of gas until I fixed it. I thought it was the traction battery so checked for codes and looked at the battery voltages etc with an ODBII setup. Nothing. Finally I figured out it wasn't the EV mode but rather the PIP that was causing the mpg drop.
    Having had good luck with SeaFoam I thought I'd give it a try. I dumped about 1/2 can of SeaFoam in and the car returned to the mid 40's mpg and stayed there for the next couple of years until we sold the car with 173K miles on it. I figure it was just some dirt in the injectors best guess.
  9. Sam Spade
    2,036
    1,023
    2017 Prius c
    Do you know how averages work ?
    IF.....your app is keeping a running average, like the onboard display will do if you don't reset it, then the poor trip performance will have a negative impact on your long term average for a LONG time. Once you burn extra gas, you can't get it back no matter how hard you try.
  10. bisco
    49,694
    how many tanks have been low, since you got back from the trip?
  11. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    When the mileage drops sharply should we be looking at the following:
    Step 1:
    Clean Traction Battery Fan
    Step 2:
    Clean EGR full system (cooler, valve, pipe, runner ports in intake plenum, etc.)
    Replace PCV Valve & clean PCV hose
    Clean Intake Manifold & PCV hole
    Clean throttle body
    Step 3:
    Replace spark plugs & clean injectors
    Clean MAS/MAP sensors
    Anything else I missed (other than the new Oil Catch Can idea that's gathering momentum; sounds like a good idea but seems a bit maintenance-heavy)?
    #11 NeilPeart, Aug 7, 2017
