dropped a quarter behind the steering wheel
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Castanea, Oct 9, 2018.
  1. Castanea
    Castanea Member
    39
    27
    Iowa
    I had some coins in the little shelf on the dashboard above the steering wheel. While picking them up, I dropped a quarter. It fell into the space behind the steering wheel. I keep it in its all-the-way-down position, and that leaves a good-sized gap above it where it goes into the dashboard. With engine off and key removed, I peered around with a flashlight, and fished around with my fingers the best I could: nothing. Neither did the coin fall all the way through everything to the floor.
    That was yesterday when I had parked at home for the evening. Everything worked fine in this morning's commute.
    Should I be worried? I have visions of it shorting some wiring to the airbag, or getting jammed in the steering mechanism or something.
    Kind of unrelated, but what do you all use that little dashboard shelf for?
  2. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    I'd be concerned about a mechanical jam as well.
    I use the shelf for whichever glasses I'm not wearing while driving.
  3. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    This is a perfect reason to spend some coin on getting your car professionally detailed. Not only will your car be easier to take care of in the long run, a car detailer has lots of ways for you to get your money back! :)
    49,506
    i wouldn't give it another thought. it is only 25 cents
    Castanea and PriusCamper like this.
  5. PriusCamper
    11,105
    4,520
    But Prius drivers are really frugal...
  6. bisco
    49,506
    i've noticed that:cool:
    Castanea likes this.
  7. Castanea
    Castanea Member
    39
    27
    Iowa
    Thanks to all of you for your comments, especially Leadfoot for actually taking me seriously, but everyone else too for the True Statements about frugal Prius drivers, of which I am one. :)
    Everything is on YouTube, including something close enough to this to be useful, namely this clip, where a guy is replacing a Gen 2 steering wheel. My guess is that the Prius C is very similar. About 4'20" into it, he removes the lower covering of the assembly, which is easily done (but the airbag and steering wheel have to come off first, from the looks of it). The inside of the lower cover has a lot of boxlike structures (which you see very briefly at 4'28", and a few times later in the video).
    My guess is that my quarter landed in one of these "boxes," just like a ball rolling into a pocket on the roulette wheel.
    I just hope it was a lucky number.:whistle:
    ztanos likes this.
  8. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    As long as the wheel keeps spinning, ride it! ride it all the way!
