Dropped my wedding ring down the air vent!
Discussion in 'Gen 2 Prius Main Forum' started by jerb, May 9, 2010.
  1. jerb
    jerb New Member
    Mpls
    I
    I need some serious help. I dropped my wedding ring down the air vent! (don't ask how) It went down the air vent closest to the windshield.
    Any ideas how I can get it out? I can't see it anymore. It's not under the car. I hope it's trapped inside the air system, preferably somewhere I can access... I'll do anything at this point to retrieve it!
    Many thanks in advance...
  2. Patrick Wong
    18,200
    6,493
    I assume that you are referring to the windshield defroster vent? Have you tried inserting the fingers of one hand into the vent to see what you can feel?
    It would probably be best for you to take your car to your local Toyota dealer's service dept for help, as it will probably be necessary to disassemble the dashboard sufficiently to gain access to the vent.
  3. a_gray_prius
    2,927
    783
    IL
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Might be worth a try, but most wedding bands have to much gold and aren't magnetic enough. If the OP isn't comfortable pulling his/her dash apart on their own then I'm with Patrick, I'd turn off the AC and get to the dealer or a car audio shop to retrieve it.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    How many wedding rings do you know of that are ferrous??
    At least it's not lost! The top dash panel is actually not
    that hard to remove, but I don't know of any nice pictorial
    descriptions anyone's done on it. I have a not-so-hot shot of
    the results when I explored mine, that's about it... if you're
    willing to tackle it yourself [for love, c'mon, you know you can!]
    start with chris-dragon-dash.pdf and match that up against the
    Toyota service manual section, realize that the ENTIRE thing
    is one piece but does uproot and slide toward you over the steering
    wheel and just barely between the [naked] A-pillars, and then
    you should be able to dig around in the defroster duct area.
    It's also a good opportunity to run in any wiring hacks you want to do
    while things are apart, and tuck them neatly in with the existing harness.
    _H*
  6. jdchappie
    jdchappie JD on RR2
    78
    Southeast Kansas
    You might call a few mechanics or locksmiths and ask if they have a borescope, the flexible type. It has a three foot snake of optical fiber that allows them to look down the vent and locate the ring. Might save some tear down if you know where it is. Jerry
  7. jerb
    jerb New Member
    Mpls
    I
    Thanks for the replies! Yes, I'm glad the ring's not lost completely, I just need to find some way to get at it.
    My ring is non-magnetic platinum, so unfortunately magnetized tools won't work.
    Thanks for the schematic to disassemble the dash -- I've been looking all over for something like that! I'll ask a Toyota dealer to do it first, but if he won't or is too expensive, I'm ready to dig in...
    The borescope idea is intriguing -- seems like a low-risk option to try first. I'll start by giving that a shot.
    I'll post the results, when/if I have some... in the meantime, any other ideas are welcome... Thanks everyone!
