Drove a Pacifica Hybrid Plug-in for a week…
Discussion in 'Prime Main Forum (2017-2022)' started by Northerner, Feb 12, 2023.
  1. Northerner
    Northerner Active Member
    121
    103
    Midwest
    2020 Prius Prime
    I was disappointed to see I was given a mini-van as a replacement for about ten days when my wife’s car was being worked on. I was less disappointed when I found it was a plug-in hybrid. While I usually drive the PP, I was designated driver for the van so here are some comments. Short version: I love the Prius Prime even more now!
    (1) It’s winter here and so often in the teens or lower in the AM. Every time I started the van, it fully warmed up the ICE (int combustion eng). There was no way to stop it. The trigger for the engine appeared to be 32 F.
    (2) I take many short trips (usually 8 Mi or less). The ICE would only turn off and switch to electric once the engine was warm- which meant it ran the car for the first four or five miles.
    (3) My MPG, even starting with fully charged battery every day: 22.5 MPG!
    I would never buy this car living in a northern climate. We complain about the 11 F and front defrost ICE triggers in the prime, but I don’t think the Prime’s ICE would have run at all for the trips I took during this time period.
  2. Trollbait
    11,504
    8 mile trips in the cold is brutal on efficiency no matter the car,
  3. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    That’s not the point here. This was a plug-in hybrid. It ideally would have registered infinite MPG since no gas should have been consumed. It probably would have been infinite in summer. But it is engineered to heat up the engine up at the beginning of every trip (below 32). That brought mileage to 22.5 mpg which doesn’t look very different from what a standard ICE Minivan would get.
    Doug McC and bisco like this.
  4. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    Out of curiosity, did you try disabling the cabin heat in the van?
    Cabin heat demand is a factor in whether or when a Prime starts its engine, no?
    I get your point about being able to start cold trips electrically, but a van used to its logical conclusion could have 7 frozen butts in it without firing up an engine to provide hot water instead of murdering the whole battery to get it halfway warm.
    Doug McC, E-GINO and Trollbait like this.
  5. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    My new Escape PHEV does the same thing. At ambient temp below 32F, the engine fires automatically when starting. Fortunately, there is a "trick" to fool the car to not start the engine when starting. But it takes several extra "chicken dance" steps for this work around. Unfortunately, DW wants none of the "chicken dance" steps, so she just turns on and drives with the engine running even though the trip is only a few miles long.
    But comparing a PP to an SUV or minivan is probably not fair. They are not in the same class. I would have purchased Pacifica PHEV instead of the Escape PHEV if it was available and affordable. We needed a larger car to replace PP and Pathfinder Hybrid.
    No, Escape PHEV does not save fuel compared to PP. But with a longer EV range, as long as we can suppress the engine firing on short trips, it will use less gasoline overall.
    #5 Salamander_King, Feb 12, 2023
    Montgomery likes this.
  6. PriusCamper
    PriusCamper Senior Member
    11,055
    4,499
    Pacific Northwest, USA
    Most all Prius requires the engine to warm up when you start the car... Just because your Prius Prime doesn't do it doesn't mean all the other Prius and plugin hybrids don't do it. And a mini-van in super cold weather is much heavier than a Prius and requires more than just the battery pack for efficient operation, even for a plugin...
  7. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    True. Actually, I park inside and have heated seats and steering wheel in the Prius Prime and that usually does the job for short trips, even in MN, unless it really is cold out.
    I did look on-line to try and disable the ICE being triggered, but only found discussions among owners complaining about it. That’s as far as I took it.
    Yes, a Prius Prime is not for transporting 8 people, nor is that minivan appropriate for transporting one efficiency minded driver in a cold climate.
  8. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    Another factor- it's a minivan. Classic uses involve moving the very young, the very old, and occasionally those in between. As a population, there's likely to be more sensitivity to cabin temperature.
    Makes me wonder if Toyota set up the prime to have a higher threshold for starting the engine overall, just knowing that so many of them would be driven with most of the seats empty, and that the driver would be likelier to favor efficiency.
  9. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    No, I wasn’t trying to get Prius Prime mileage out of the minivan. I was just curious to see what happened since I am a fan of the technology. I just expected better than I got. Some days I have a routine where I drive 8, 5, and 5 miles with a one to three hour stop between destinations. I was probably spending more energy just heating up the ICE three times than transporting myself.
    Were you surprised like I was to see the 32 degree trigger?
  10. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    We have sold several through the hybrid shop where I work part time. They are a real pain to work on besides the cold weather issues you encountered. (Not much cold here in Tampa. ;))
    Doug McC likes this.
  11. Louis19
    Louis19 Active Member
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    If I may add AFAIK the Prime uses a heatpump , permetting EV mode operation down to 14F without ICE kicking in.
  12. Salamander_King
    10,970
    8,853
    New England
    Yes. But for the Escape PHEV, this turned out to be a software update Ford applied to late 2022 Models. Also, the 32F threshold is automatic, the engine starts regardless of the HVAC or any other electronic settings. No heat required, still engine comes on. The earlier Escape PHEV owner did not have this happen, unless it was brought into a dealer service and the software update was applied. The fact Ford changed the threshold temperature for the engine starting indicates that not starting the engine in earlier models must have caused some problems. But I am not exactly sure what the reason was.
    Yeah, there is no way SUV or minivan PHEV can compete with PP for its efficiency. Also, the philosophy is different. "Prius" has been a car for high efficiency. The fact that the car will automatically default to the EV mode is one example of such a difference. On Escape the default mode is EV-Auto. And under EV-Auto, the propensity of the engine to start is far more likely than the EV-Auto of the PP I had. I really was not expecting the Escape PHEV to be made for efficiency, but I wonder how Rav4 Prime would behave in a similar situation?
  13. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    Good reminder.
    I'd think that could account for a lot of the difference right there. I imagine it would be crazy expensive to put a minivan-sized heat pump in that bus.
    Louis19 likes this.
  14. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    The "chicken dance", LoL. Love it!
  15. Trollbait
    11,504
    The MPG would be infinite, but the miles per kWh would take a nose dive.
    It is a PHEV, it will use the engine when that is the best option. The Prius Prime having a heavy EV use mode is a quirk for the North American market. EV mode in Europe is our EV Auto. Their EV 'only' mode, EV City, flat out states it will fire up the engine when flooring it.
    Fiat didn't choose to have the ICE come on in the cold to piss off drivers. Neither was the lack of driver control over the system designed that way; it was to keep things system for their consumer base. The Pacifica hybrid does not have a heat pump. Those are still relatively expensive for cars.
    Transaxle fluid not warming up?
    Dry out the motor oil?
  16. bisco
    49,371
    My pip has no heat pump, and the engine rarely runs in cold weather
  17. vvillovv
    vvillovv Senior Member
    3,606
    1,270
    NY
    This post is probably neither here nor there in many respects. I spoke with a Chrysler plugin minivan owner 4 or 5 years ago at a charger where we were both plugging in. The three things I remember from the conversation were he was excited to mention the minivan got 38? ev miles of range, it charged to full
    SOC in 2 hours and he wasn't worried at all about the battery lifespan, he said he was going to trade it in after 2 years. To each their own and thanks for your review @Northerner :cool:
  18. hill
    8,153
    Not exactly .... Trigger is 15°. But 32° is when you run defrost and or heater. Ours is in the heated garage so we can typically drive a good 24 (vs 33) miles before all the electricity is used up in freezing weather - or until the thermostat sees it's below 15°
    Yes - many other PHES do better in cold weather since they incorporate a heat pump.
    Using Gas & Electric winter & summer we average about 40 mpg. That's based on 25 MPG in Sub-Freezing temperatures and 60° in the summertime.
    YMMV turning on how long most of your trips are as well as weather.
    But don't forget even the Prius can get mileage in the twenties on short trips in Alaska. So much more a 5000 lb vehicle.
    #18 hill, Feb 12, 2023
  19. Salamander_King
    10,970
    8,853
    New England
    I wish I know the reason, but so far I have not found it. The fact they did not do the total recall on the previous models but implemented this update on newer models seems to suggest that this is not a 100% critical issue, but I would like to know if it's OK to keep forcing the engine to stay off when it is below 32F. For one thing, the electric motor in Escape PHEV is not as strong as Rav4Prime, for this reason, even when the temperature is above 32F, and the car is on EV Now mode (pure EV) with plenty of battery, it asks for permission to turn the engine on. So, yeah, unlike PP, it is very hard to keep the car happy with electricity only.
    #19 Salamander_King, Feb 13, 2023
  20. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    Ahhhh, I’m not ever going to need a Pacifica, but I’d get heated seats if I did -just to keep the engine from running between 15 and 32 then. I often get by in my PP in that temperature range without the heat on at all since warming the seat and steering wheel is sufficient if I’m in my winter jacket.
    Louis19 and Salamander_King like this.
