Drying out a wet car
Discussion in 'Prius c Main Forum' started by MattFL, Oct 11, 2025 at 7:43 PM.
  1. MattFL
    MattFL Member
    183
    50
    Has anyone had luck drying out a wet car with soaked carpets? If yes, did you manage to get it dry without taking out all the carpets?
    Backstory: a local shop (who has been good for us in the past) just replaced our AC evaporator about a month ago, today my wife says the car is getting funky (she is right!), so I poke around and discover they neglected to connect the evaporator drain hose. So we've got about a month of S. FL humidity soaking our carpets, probably several gallons of water. I will take it back to them, but I'm also thinking if I want something done right I need to do it myself.. Any tips or suggestions are welcome!
  2. ChapmanF
    17,831
    I wouldn't mess around. A shop vac of available to suck out any water possible, then of at the very least lift all the carpet off the floor with some blocks underneath. Open car, fans if available. May still end up needing a chlorine dioxide generator or ozone generator to polish of the last of the funk
