DTC 1253 - 134
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by emanboulay, Apr 29, 2019.
  1. emanboulay
    emanboulay Junior Member
    33
    Hi everyone. I'm looking for advice for my Prius 2006. Changed the actuator (used), tried swaping the Skid computer, changed the main 30A fuse that had blown, swaped relays 1 & 2. When testing Main motor relay 2, pump activates. When testing Main motor relay 1, I hear a clic but pump remains off. Wanted to repair and give the car to my son, but I fear the car will be going to scrap. Also have a C1345. Will try troubleshooting wires but any hint will be apreciated!
    Etienne
  2. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    30amp fuse I look for a short wire
  3. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Test the fuse jack to ground if it shorted unplug plugs intel it gone what left mostly shorted
  4. emanboulay
    33
    Hi. Thanks for your help. Battery disconnected and tested removing relays and fuses in main fuse box, accumulator disconnected, even Skid computer unwired and I get 0.560 when testing resistence between positive wire in fuse box and body. When removing the 15A dome fuse... I get 0.590 but that seems pretty far from 1.0...
  5. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Has to be a wire touching the frame .5 still zero. Have someone watch it and move wires
