DTC: P0A0D30 in 2010 Prius III gen 3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MARK A SLOO sloo, Aug 16, 2018.
  1. MARK A SLOO sloo
    MARK A SLOO sloo Junior Member
    38
    Minneapolis
    I have a 2010 Prius presenting DTC: P0A0D30. I've searched and do not find any information about this code anywhere. Has anyone seen this code before? Where can I go to find out what it is? Many thanks!
    49,507
    welcome!
    the codes are all in the service manual. are you reading it with tech stream?
    what behavior is your car exhibiting that led you to scan for trouble codes?
  3. MARK A SLOO sloo
    38
    Minneapolis
    I read the code with a Vgate iCar ELM OBDII (OBD2) transmitter and Car Scanner app on iPhone.
    I replaced the 12v battery and on Power up the display says: "Check Hybrid System" and when I attempt to shift into D or R it refuses and says "Shift into P" on the display.
    I read the DTC and even did a "Deep Scan" using the Car Scanner app and there are no codes.
    Does anyone know anyone in Minneapolis with a TechStream I could borrow/rent. I've ordered my own TechStream but will take a couple of weeks to get here.
    Or, can anyone recommend a good independent repair shop for this? I really don't like the idea of having it towed to a Toyota Dealer.
  4. MARK A SLOO sloo
    38
    Minneapolis
    Thank you for your reply. The "Check Hybrid System" showed up on the Display and car would not shift into gear. The 12v battery turned out to be dead (original battery from factory).
  5. bisco
    49,507
    Congrats!
  6. MARK A SLOO sloo
    38
    Minneapolis
    No Congrats yet. On Power on, the diplasy says "Check Hybrid System", it won't go into D or R, and no codes are generated.
    So, I am trying to find someone in Minneapolis with a TechStream I could borrow/rent. I've ordered my own TechStream but will take a couple of weeks to get here.
    Know anyone independent in Minneapolis, Minnesota that can help? I really don't like the idea of having it towed to a Toyota Dealer.
  7. bisco
    49,507
    sorry to hear it. try eric becky in madison, maybe he knows someone closer.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
  9. JC91006
    16,482
    8,400
    Does it go into ready mode? Did you mess with the orange interlock on the hv battery?
  10. MARK A SLOO sloo
    38
    Minneapolis
    No, It does not go into READY mode.
    Yes, after my above described experience, I did disconnect, inspect, then reconnect the orange Safety Plug and I did it properly according to the many posts on the subject. I also disconnected, inspected, and reconnected the other electrical connectors plugs near the ventilation fan as other posts/threads suggest.
  11. JC91006
    16,482
    8,400
    Did you lock the orange interlock? Slide it to the right afterwards? Screenshot_2018-08-22-21-23-37.jpeg
    Raytheeagle likes this.
  12. MARK A SLOO sloo
    38
    Minneapolis
    Thank you for the suggestion. I will contact him.
  13. MARK A SLOO sloo
    38
    Minneapolis
    Ok, congrats are in order! @strawbrad (Brad with Minnesota Hybrid Batteries, http://www.minnesotahybridbatteries.com) came to my aid with his Techstream setup and the codes shown in the images below are from the Techstream. It showed code P3004 which is the inverter IPM (Intelligent Power Module). Brad mentioned the extended warranty on the inverters, so I promptly looked it up and found what I needed here: https://attachments.priuschat.com/attachment-files/2015/10/96076_Warranty_Enhancement_Notification_ZE3.pdf
    Armed with this info, I called the nearest Toyota dealer and asked if they could perform the extended warranty work. I had never been to this Toyota dealer and I bought the car used, but they performed the work no problem and it was !00% covered by the extended warranty.
    Thank you everyone who helped! Thanks also to Toyota for standing behind their products!!
