DTC P1121 (coolant flow control valve psoition sensor stuck) went away
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by exstudent, Jan 8, 2014.
  1. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Hi All.
    The CEL came on, but went away a few minutes later. When I got home and connected an OBD2 scanner, the DTC code was P1121 (Coolant Flow Control Valve Position Sensor Stuck). There is a Toyota Service Bulletin about this code, that many of you already know about.
    Both, drivability and engine noises seemed to be the same, before, during, and after the CEL came on.
    The Prius in question is a 2007 with 121,000 miles on it.
    Has this happened to any of you too? Should I just plan to change this valve some time soon? What could happen if I don't change it soon enough?
  2. Patrick Wong
    18,200
    6,472
    Yes, you should change the valve at a convenient time. As you've noticed, the failure of the valve does not impact power train performance. This is solely associated with the coolant heat recovery system with regards to speeding up engine warmup.
    The valve failure might impact your cabin heater's performance.
