DTC U0111
Discussion in 'Gen 2 Prius Main Forum' started by Antonio Davila, Nov 24, 2014.
  1. Antonio Davila
    Antonio Davila New Member
    tampa Fl.
    Can someone help me with dtc U0111, what are the causes that lead and posibes solutions
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    What are you using to do the scan? What symptoms does your car show? Have you had any work done on the car? More info please.
    This DTC indicates a communication glitch between the HV Battery ECU and the rest of the Canbus has been logged. The only posts on PriusChat of someone getting this code indicate that it occurred when they plugged in the scanner while the car was in Ready mode. It did not happen when they plugged in first, and then made the car ready.
    Gen II Prius Individual Battery Module Replacement | Page 2 | PriusChat
    Britprius likes this.
