DTC with OBDII Scanner
Discussion in 'Generation 1 Prius Discussion' started by groo1887, Feb 6, 2011.
  1. groo1887
    groo1887 New Member
    San Mateo, CA
    2001 Prius
    My 2001 has the triangle warning light.
    I am trying to read the DTC with a scantool OBDII scanner. I am using an ELM323 scanner and Digimoto software. The software returns no errors when I interface using the serial console I get the following, which I have not been able to corelate to traditional DTC format like P3010. How do I get the DTC codes?
  2. Patrick Wong
    18,200
    6,472
    Besides the master warning triangle light, have any other warning lights appeared on the dashboard or MFD?
    Maybe your car hasn't logged any DTC, if no other lights appear.
  3. groo1887
    groo1887 New Member
    San Mateo, CA
    2001 Prius
    No other lights I get the PS, Battery and Warning Triangle on the screen. Car seems to be functioning normally.
  4. Patrick Wong
    18,200
    6,472
    OK, then some DTC exist. If your code reader won't retrieve the DTC, you'll probably need to visit your Toyota dealer for assistance. It is likely that the hybrid vehicle ECU or traction battery ECU have logged those codes.
    Looking at the MFD, although three warning icons appear, one of those icons will typically be highlighted more than the others. Which one is highlighted?
  5. groo1887
    groo1887 New Member
    San Mateo, CA
    2001 Prius
    The battery Icon was highlighted. My suspicion is that the error may be due to the aux 12V battery failing (haven't replaced it in the last 6 years and the traction battery seems to be functioning).
    Is there a way to get to the traction battery ECU via the OBDII port and the console interface?
  6. Patrick Wong
    18,200
    6,472
    I am not aware of a way for you to retrieve traction battery ECU DTC.
    Since you say that the car has no driveability symptoms my immediate guess is that your car has logged DTC P3009 which is a high voltage ground fault error.
    It wouldn't hurt for you to replace the 12V battery if you plan to keep the car, but I doubt that will help this particular issue.
  7. ChapmanF
    15,518
    Look over the Classic Prius and ScanGaugeII thread, where vincent1449p has codes for reading battery ECU values using a scangauge. If you know what you're doing with your ELM interface you should be able to use it to make the same queries.
    What you see in the XGauge tables in that thread will probably be easier to read and make sense of in the NHW11 database over at obdchat.sourceforge.net, except that so far that database only has PID-based queries and not the ones for DTCs; you'll have to refer to the XGauges in the scangauge thread for those for now.
    -Chap
  8. groo1887
    groo1887 New Member
    San Mateo, CA
    2001 Prius
    I tried some more but couldn't get to the Hybrid ECU with my scan tool. I broke down and took the car to the dealer. He pulled the following codes:
    C1259
    P3000
    P3006
    P3190
    P302
    He recommended a HV battery replacement ($2300 + $700 labor) and to shim the valves ($1100 - $1500 depending on how many need shimming)
  9. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Time to get your car to Luscious Garage | Hybrid Specialists in SF. They can handle these problems for a lot less than the prices your dealer quoted.
  10. Patrick Wong
    18,200
    6,472
    It sounds like your car needs a traction battery replacement, although I am surprised that you have not noticed any driveability symptoms, such as the gasoline engine running whenever you press the accelerator pedal, no matter how gently - and impaired mpg.
    I would forget the engine valve adjustment, and instead have the iridium spark plugs replaced, and the throttle body interior and throttle plate cleaned. That may take care of the P3190 and P0302 codes.
  11. groo1887
    groo1887 New Member
    San Mateo, CA
    2001 Prius
    Talked to Luscious garage. I am hesitant to go for their genII rebuilt packs. While they are cheaper they can't guarantee the mileage on the rebuild cells. Sounds like most of their cells come from totaled Prius'. After the rebuild they only offer a one year warranty.
  12. RobH
    RobH Senior Member
    2,369
    979
    70
    I thought one year was the standard warranty on replacement packs, be they OEM or rebuilt. Check with the dealer, but I doubt that they'll offer anything better.
    Luscious could install an OEM pack if you insist. But I think you'd be getting an older technology unit with less potential life in it than a properly rebuilt unit with Gen2 modules.
    Before deciding on any replacement, consider that there may be corrosion issues that could be corrected. A dealer will typically just replace the unit, while a place like Luscious or Art's Automotive will do a deeper diagnosis. Maybe you can get another year's worth of service out of the current pack if it's cleaned up.
    So my call would be to have Luscious diagnose your battery. If it turns out that it really needs replacement, have them replace it with a rebuilt unit constructed from Gen2 modules.
    As for the dealer wanting to shim the valves, I've never heard of that being done on a Prius. Sounds like excess maintenance to me. Definitely worth a second opinion on whether it's necessary or not. The money would be better spent on a major tuneup, including full fluid and belt replacements.
