DTR lights as fog lights
Discussion in 'Prius c Technical Discussion' started by Joshua, Sep 6, 2012.
  1. Joshua
    Joshua Junior Member
    56
    Atlanta, GA
    Is it possible, or has anyone figured out to have your daytime running lights come on with your low beam headlights?
    I think it would look good, and save money from buying separate fog lights.
    Thank you
    Joshua
  2. Joshua
    56
    Atlanta, GA
    Sorry this is in the wrong forum can a moderator move it to regular Prius technical or delete it?
  3. SILVERPC3
    SILVERPC3 New Member
    Dallas TX
    I am interested in doing this, however I have no time or know how to do it.
    Joshua likes this.
  4. Joshua
    56
    Atlanta, GA
    And it seems noone else does or has thought about it.
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    ive never thought about it. but i think you would have to change something with the ecu itself. the drls are controlled thru a module. so i guess in the module you can rewire it to always be on with the car or always on with the low beams.
