Dumb Question on Braces and Bars
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ThatOddMan, Nov 24, 2020.
  1. ThatOddMan
    ThatOddMan Junior Member
    64
    25
    Alhambra, CA
    Cusco Front Lower Arm Bar
    SKU: 942 475 A
    Cusco Front Power Chassis Brace
    SKU: 951 492 F
    Are those two installed on the same location/spot/place? Like an either or mod not both?
    Do the plastic covers underneath needs to be permanently removed for the mods to be installed?
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    You own a Prius.
    While both the Bar and the Brace offer you the chance to have blue parts under your car to point at, it will still be a Prius.
    The Bar will add blue near the centerline of the wheels, while the brace adds blue back nearer the Catalytic Converter.
    Bar
    Brace
    It is all where you like your blue decorations to go.
    SFO, Majafamily and Ed Beaty like this.
  3. Jim Swart
    Jim Swart Member
    55
    40
    Portland, OR
    No.
    ThatOddMan likes this.
  4. orenji
    orenji Senior Member
    5,886
    3,487
    No covers need to be discarded. Only the heat shield for the brace. Plus the braces do work and stiffen up the chassis, plus add blue :) So regardless if it’s a Prius or not, they work and help the handling of the car.
    _xw30_chris, ThatOddMan, durr and 2 others like this.
