Dumb question on engine water pump replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by triollie, Jan 9, 2018.
  1. triollie
    triollie New Member
    New Jersey
    I have a 2005 Prius with 115,000 miles. When I initially bought it at around 100,000 miles, I changed out the engine coolant (as well as the inverter coolant). During my last oil change, I noticed that I have some slight weeping around the engine water pump so I'm planning to replace that.
    Because I'm being a bit lazy, if I just remove the water pump without removing draining the coolant, would I lose almost as much coolant as if I've drained it? Should I just not be lazy? :)
    Thanks in advance.
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Check thew Toyota dealer. There were a number of warranty replacements for that water pump that your car may not have received.
  3. JC91006
    16,768
    8,565
    You will lose about 1/2 to 3/4 gallon of coolant. Much less than if you were to drain.
