Dumpng your old inefficient Fridg
Discussion in 'Environmental Discussion' started by hill, Jul 11, 2012.
  1. hill
    8,910
    The utility company offered us $35 (it's a program to save electricity) to take our 13 year old 28 cubic foot stainless side by side out of the system. One of our tenants offered us $100 for it. Is that wrong? We didn't need the dough, but our tenant actually got a more modern fridge through the sale - and THEY can get $35 for their old energy hog. I must say - after running the numbers off the Kill-a-Watt ... the 13 yr newer model is a full 300% more efficient. I don't know how they do it.
    52,348
    insulation?
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    We replaced a side-by-side last year with a top-fridge-bottom-freezer of the same size. I bought one without an opening in the door for ice to improve insulation, and replaced that utility with a Zogirushi (sp?) dispensing thermos for ice water. By kill-a-watt we use about 750 wh a day for most of the year, although that peaks to 1200 wh a day during the hottest summer months. Average annual consumption is under 1 kwh/day; the EPA rating is ~ 1.1 kwh/day.
    This is about 1/2 the energy the 16 y/o we sold for $200. Most interesting to me and somewhat unexpected: most of the money savings is from less fruit and vegetable rot, and the top-down design along with smart interior design make this fridge MUCH more accesible. Same nominal size, but easily 20% functionally larger.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    What's more remarkable is that 13 years ago, that fridge was way more efficient than fridges from 13 years before that. When you go back that far efficiency wasn't much of an issue.
    austingreen likes this.
  5. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    Energy star is probably the most sucessful program of the DOE
    About ENERGY STAR : ENERGY STAR
    Even appliances that are not energy star rated, are more efficient because of advances and competition from the program.
  6. hill
    8,910
    I'm thinking "breath-ability" . . . our 36" wide had to literally be jammed into the space, but only after removing the light switch next to the wall, and the floor molding. It was so jammed in between the wall and the kitchen counter it couldn't ventilate away its own heat/humidity. The wall had gotten moist over the 9 years we've lived there . . . wet, black furry mold. I TOLD my wife when we moved from the old house we either needed a smaller fridge, or a wider space between wall and counter/cabinets. Lost that battle - until now. Of course I didn't say, "I told you so" when I pulled the dinosaur out from the wall (it made a disgusting 'sucking' sound, as the moldy wall/paint gave way) ... those were just my 'inside' words. :) I'm thinking the new model doesn't have to run as hard now that its discharged heat can escape.
    This new model (Samsung) has a 4th door (refer), above the bottom freezer. So I'm guessing less heat escapes when less doors are open, presuming you don't have to hunt for the cheese, because you remember where you put stuff. Plus, all new refrigerators seem to have LED's now, rather than little mini 75 watt heater incandescent bulb/lighting, that require the fridge to cool them down when you open the doors. It's got an unusual running cycle too. The old model, a constant 235 watts when the compressor comes on. The new on very briefly cycles up to 300 watts, then quickly down to 120-150 watts, then shortly thereafter, down to a skimpy 80watts. Bazaar.
  7. icarus
    icarus Senior Member
    4,884
    976
    earth
    Not to be political, but this is a great example where the market follows the government mandate, despite loud opposition! To keep it simple, fridge prices have gone down,, and Ef rates have gone up, largely due to the market being forced to build better stuff. How about higher CAFE standards, CO2 emission controls etc?
    Icarus
  8. fuzzy1
    10,602
    While I normally wouldn't approve of reselling energy hogs, this transaction certainly was beneficial. They weren't buying it to have a second fridge in the garage.
    I wanted to replace a 1989 fridge during a household appliance efficiency upgrade six years ago, but we could not find anything that met all our wants. A year ago, the fridge made up its mind for us, forcing us to quickly trim our wants to conform to what actually exists.
    My Kill-a-Watt had measured the old one as hair over 800 kWh/year, based on a mid-spring measurement. That was substantially less than its energy label, likely due to our cold house. The new one tested out as 40o kWh/year, slightly under its label, measured in July when the house is warmer.
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I'm a bad boy, because I just added a 2nd fridge, although only 10 cuft. Rated 300 kwh annually.
    I didn't check what type of light is in it, but it's solely for the purpose of my new beer brewing hobby. I think my 5 year old kitchen fridge, is rated 400ish kwh/yr. I did swap out the old incandescent bulbs (2 - 30? watt ones) with a single LED one that doesn't provide much light.
    I don't think it was bad to offload the old one to a tenant. You upgraded your efficiency, the power company would have junked a perfectly good fridge that your tenant is now able to use. So, one upgrade is still better than none. There's always a market for the used, working appliances.
    Just make sure you keep the coils cleaned at least every 6-8 months on them, including where the exhaust heat blows out (seems most blow out the front of a unit). I had to turn my fridge a full notch colder, and was worried about something going wrong with it. Turns out, just needed to clean the exhaust part and coils, because they were pretty clogged with dust and cat fur. Local appliance shop recommends every 3 months for folks with pets. I got a $10 coil brush, which I'm sure will get used enough to make worthwhile.
  10. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    This is analogous to the question of whether it's better to buy a new Prius than to keep running an older traditional vehicle. The issue is, what happens to the average efficiency of the vehicle "fleet" when you make the transaction.
    The simple way to think of it is, the worse the fridge that gets junked, the more good you have done. The fridge "fleet" improves by the net difference between your new fridge and whatever fridge ultimately gets junked as a consequence. So if trading results in a worse fridge being junked, then you've done better by trading. But if no fridge got junked, then it's a dead loser.
    Obvious the real world is somewhat more complex. What if your neighbor would have been forced to buy a modern very-efficient fridge when theirs ultimately died, and so on. But to a first approximation, junking the worst possible appliance right now gives you the best improvement right now. I'd say you did better by trading than not, assuming your neighbor junked a fridge that was less efficient than yours.
    First related footnote: The energy required to produce the fridge is small compared to the energy required to run it. See, e.g., figure 3 in this article ApplianceMagazine.com | Assessment of the Environmental Impact of Household Appliances - Engineering - Energy Consumption
    This is pretty much true for all household appliances. So junking a few years of potential useful fridge life has minimal energy impact. Seems wasteful, but from an energy use standpoint, it's not very wasteful.
    Second related footnote: Chest freezers are now inefficient, compared to fridges. That's due to the improvement in fridge efficiency. The old conventional wisdom was that a chest freezer didn't use much energy -- compared to a fridge. But fridges have gotten much more efficient, while chest freezers haven't, that the old wisdom is now wrong. The upshot is that nowadays, running a typical chest freezer (15 cu ft, say) is like running a second fridge. E.g., looking at the Home Depot site, their best-selling fridge (18 cu ft, top-freezer model) uses 383 KWH/year. The biggest top-freezer model they sell uses 422 KWH/year. Their best-selling 15 cu ft chest freezer (energy star rated) used 354 KWH/year. Even a 7 cu ft chest freezer (which is small) runs 244 KWH/year.
    xs650 likes this.
  11. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ..some states (eg VA) have green appliance rebates. We got a nice new HE washer from Home Depot on Black Friday for $150 after $350 rebate from VA. I've been trying to play same game for refrig but no luck so far.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    Quite a deal :)
    I made out like a bandit with my clothes dryer. I bought a can of paint, clothesline and pins for about $10, and converted an old unused swing set to a dryer. I used to think that 200 kwh/month total electric consumption was a nice target, but now I am getting greedy and am eyeing 100 kwh/month. No fancy PV, geothermal etc, just cost effective unsubsidized conservation.
  13. chogan2
    1,066
    756
    Virginia
    That rebate amount is ridiculous, and makes that program just look plain stupid.
    But I just looked up the regulation, and it says $75 for a washing machine. Googled it, and got the same results across several sources. The largest rebate amount listed is $300, for a house heat pump.
    How did you manage to get $350 for a washing machine?
    Virginia Department of Mines, Minerals and Energy - American Reinvestment and Recovery Act
  14. hill
    8,910
    I don't know about wjtracy's area rebates, but on top of electric company rebates, for our high efficiency front loading washer we also got rebates from the gas company, as well as from the Irvine water district. All 3 agencies apparently felt they were getting a bargain. Some of the surrounding counties pitch in too, on top of each other ... in essence allowing one to double dip. Our neighboring county and a couple cities do that with PV solar, where you get incentives from your city, county, as well as state and fed. The more the merrier.
    I don't know how any high efficiency incentive program can look outright stupid, as long as the petro industry gets a tax-free hall pass, decade after every decade. As long as we pass-on all of the hidden / high costs of fossil fuel that gets couched in global military costs - paid for by doubling and tripling our fake paper money supply (which effectively robs the value of money you save for retirement) even the poorest of middle income people can buy inefficient transportation, which effectively wipes out a ton of enviro-gains going by folks trying to do the right thing.
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ Subsidies to buy lower consumption devices are wasteful to the extent that people offset the device's savings by increasing consumption or use elsewhere. In the absence of higher electricity costs that encourage conservation, subsidies are an even worse idea than usual.
    This past week my house is using 6 kwh/day. It is 2800 square feet, and electric is (still!) used for hot water and cooking. Consumption *is* elastic. For most people decisions to use less energy are driven by their monthly electric bill.
    Over the past couple of years I have seen way too many examples of affluent people who use taxpayer subsidy to put up huge PV arrays that greenwash a high consumption lifestyle. The irony is they often think they are setting a good example for others to follow.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That has been my observation too. Some if not most of the homes with PV arrays in my community belong to heavy electricity users. They seem to have gone PV because of high electric bills and the massive PV arrays allow them to continue using large amounts of electricity without the large bills. They conveniently don't count what the PV system cost them and the taxpayers. I don't begrudge them that though because they still do serve a useful purpose. They are helping get the PV industry off the ground and producing lower cost systems.
  17. hill
    8,910
    . . . and, power gluttons are going to use lots of power anyways - so if it's drawn from solar - our weak grid benefits by not taking such a huge hit. Same thing with those giant "Sub-Zero" branded refrigerators (found in high-end homes). Although it's not such a grand scale as central air - it all adds up - giant house or small.
    SGH-I717R ? 2
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That is an excellent point about the weak grid. I think that in the short term that is more important than the energy conservation.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    That depends how much it costs. More to the point though, if they are paying the actual unsubsidized cost of additional clean energy to match their use, I don't care how much energy they consume.
  20. Mendel Leisk
    41,858
    Very true!
    Manufacturers should be required to make these heat radiators more accesable. Our is buried inside: back panel needs removing, and and also the fan mounted on the coil, for half-decent access. I don't believe there anything in the fridge manual about periodic cleaning, either.
