DVD Won't Eject
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mitchla, Jun 6, 2008.
  1. Mitchla
    Mitchla New Member
    107
    I'm trying to eject my NAV DVD but it won't come out. I'm pressing the button called PUSH. I'm trying quick presses and long presses. With the car on and with the car off. Nothing. (I have the Coastal Tech "kill-I-agree" dongle doohickey installed, but I doubt that would affect anything.)
    There's no machine sound of it trying to eject. Nothing.
    Any suggestions?
    Thanks.
  2. Patrick Wong
    18,200
    6,480
    Just for fun, try disconnecting the wire harness connectors to the nav system (to cut the 12V power). Then reconnect them, and see if you can eject.
  3. dogfriend
    7,512
    1,188
    Carmichael, CA
    IIRC, you have to push the button and slide it over to the left. You should see a door in front of the DVD slot drop down and then the DVD will eject. The car must be on. IIRC, I had it in IG-ON.
  4. Mitchla
    Mitchla New Member
    107
    Yup. Push and SLIDE. That did it. Thanks.
