Dying traction battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Al Bundy, May 21, 2018.
  1. Al Bundy
    Al Bundy Member
    140
    69
    florida
    Hello..
    My 2008 Prius with 164000 miles is giving me a problem..
    The bar graph on the screen goes from all blue after sitting overnight to 1 or no purple within a mile when I take off in the morning.. its quickly charges back up to all blue and sometimes into the green with 10 miles..
    drops like a rock again with the ac on...
    12 volt showing good charge at 14.2 when driving, its under 2 years old
    I used a friends laptop and recorded the voltages as shown in the pictures.. all seem normal, no warning lights or error codes, all internal resistance is consistent.. .24 or .25
    Is the pack dying or might I have another issue?
    is there a way to tell whats going on without removing the pack and blindly swapping modals?
    thanks
  2. John McG.
    John McG. Junior Member
    55
    23
    Yes, you don't want to start fiddling, certainly not yet. If you have TechStream, you should run an active load/stress test on the HV battery. You can usually get a garage savvy in Prius hybrid to do it for $50. If your not pulling codes, you're likely ok. How is the gas mileage?
    Al Bundy likes this.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Yes, this is one sign of a weak pack. You might consider the option of grid charging but (IMO) you and other gen 2 owners should have already been doing that by now for maximum benefit/cost ratio. Rebuilt/refurb packs sometimes advertised as "new" are a gamble and only worth what their warranty (and company) will do as they will fail too.
    See the link in my signature to see what I did when faced with the same scenario.
    GOOD LUCK!
  4. John McG.
    55
    23
    Once you know you have a bad/weak battery, you have a number of options. A lot depends on your mechanic capability, how long you want to keep the Prius, and your pocket book. When it comes to the "triangle of death" take your time getting a good diagnosis or you could pay dearly.
  5. fotomoto
    5,602
    3,778
    So. Texas
    Going by the voltage readings, once the delta between blocks 1 and 12 becomes too great, a P0A80 code could activate and ultimately turtle mode.
  6. Al Bundy
    Al Bundy Member
    140
    69
    florida
    MPG is still in the mid 40's where its always been..
    how do I do the test you mention..
    my friend has the tech stream on the laptop but never uses it since he sold his prius last year..
    might try to buy the laptop off him..
    thanks
  7. Al Bundy
    Al Bundy Member
    140
    69
    florida
    so its over charging on 1 & 12? (new to the repair end, not sure about the delta term) are those the ones I should change out before total failure?
    thanks
  8. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks,I will review your link... im not sure how much i want to invest in this car due to its age.. i have had it for about a year and its been pretty good but as one expensive part fails I guess others will be close behind.. just seeing what my options are at this time as to its current issue.. thanks agan
  9. fotomoto
    5,602
    3,778
    So. Texas
    Once the difference between upper and lower voltage values becomes too great, the battery computer will trip the fault codes and if the delta is large enough (one or more module failures), protective "turtle" mode will activate shutting off the EV part of the equation and only allowing the ICE to run and power the car which it isn't designed to do by itself (hence turtle mode).
    Yup, that answer is different for every person encountering due to many factors. In my case, my 06 has very low miles and I want it to run as reliably as possible for several more years so I went with a new Toyota battery.
    GOOD LUCK!
  10. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, I think Ill order 4 mods and follow your steps before it dies.. just wanted to get ahead of the problem as soon as possible.. I dont mind throwing $150 bucks and a few hours at it.. I cant really justify 2 or 3 grand for a car this old .. thats about what its worth
  11. Priusyipee
    Priusyipee Active Member
    350
    269
    Upstate New York
    I did some extensive reading on the subject and found some owners who have allowed the car to warm up for a few minutes in the morning before initial take off. This seemed to keep the battery from draining. I was experiencing the same situation (with my 2008) that you have with your battery. A quick discharge down to one purple bar and then back up to six within about 6 miles. The discharge was happening while the engine was running and the car was in motion. Now that I let the car warm up a bit, the problem has completely disappeared. This was a problem that only occurred first thing in the morning after the car had sat overnight but oddly enough, never had these symptoms when leaving work in the afternoon. I have a 44 mile commute each way - all open road commuting to and from mountains and valley.
    PS - I also have a 2005 Prius with the (completely) original hybrid battery now over 325,000 miles!
    Aaron Vitolins and Al Bundy like this.
  12. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, Ill try it .. seems odd because if you arent driving the battery isnt charging... just sitting in the driveway isnt producing a charge... mine is like yours, discharging as you drive first thing in the morning even with the ICE running.. WOW that 05 sounds more reliable then the newer ones.. mine has half the miles and is already dying
  13. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    That actually is not true. During the 50 or so seconds (assuming the A/C is off), there is a small amount of charge going into the battery. But this is not the primary reason for waiting for the engine to cut out (as it passes from stage 1 to stage 2 of the Prius warm-up), it is to allow the ICE to participate in driving the car which, once in stage 2, it will do, but it does not do while in stage 1. Stage 1 is primarily focused on getting the ICE and cat warmed up as quick possible, and while this is going on, the electric motor primarily drives the car. This is why the HV battery can discharge quickly if driven in stage 1, especially if that HV battery is starting to get towards its end of life.
    As explained above, while the ICE is running, it is not contributing a lot to provide motive power.
    See the link in my signature to read more about the 5 stages of Prius warm-up.
  14. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, I see that now.. I waited about 2 mins after ICE cycled and stop then took off and it didnt drop into the purple...
    it did drop when i turned on the AC a few miles down the road so I assume I do have a weak battery after all..
    i read a few posts on using RC car charges to balance the mods.. I was wondering if it really works, and what kind to get.. some are only $18 each on e bay..
  15. Al Bundy
    Al Bundy Member
    140
    69
    florida
    IT WORKED! im sure Ill have to rebuild the battery soon as its still dropping fast with the ac on (Im in Florida the AC is always ON) but its not dropping into the purple anymore when i get to the end of the subdivision.. thanks
    Aaron Vitolins and Priusyipee like this.
  16. Priusyipee
    350
    269
    Upstate New York
    Wonderful! Since I am up near the Canadian border, I can get away with not using the A/C for now. It seems to be well document that extreme heat is the worst enemy of a traction battery. When I start the car, I turn the temperature up enough for the ICE to kick on and let it run 4 - 5 minutes before I leave. I know that the battery in our '08 with 180,000+ mi is weaker than the '05 with 325,000+mi because the '05 does not need this warm up. It's a temporary fix but it will extend the useful life of the battery. The only difference between the cars is that '05 was purchased new and the '08 was purchased used.
  17. Al Bundy
    Al Bundy Member
    140
    69
    florida
    yes the heat here kills everything.. thanks again for the tip..
    Priusyipee likes this.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Mine was doing the same thing. I bought the Prolong Hybrid battery charger and the discharger
    And did a very mild discharge and so far a year later the battery looks like it’s brand new.
    Ymmv.
    Your going to have to do something as it will soon throw a code and then your done. It’s either new battery or whack a mole repair.
    I bought the original system that uses the light bulbs to discharge. I think it’s s good nvestment because I can easily sell it down the road.
  19. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    When I bought my first prius (a 2005) almost 5 years ago, it had over 200k miles AND it had been sitting for half a year. So it's battery was sorta week. I had a routine, I would hop in the car, push start, quickly depressed the gas pedal just enough to start the engine (didn't want to wait 7 seconds.. I know) let it run while I put my seat belt on, plug in my phone. I would then pull away and gently keep it costing trying not to take much energy from the battery. It would pretty much stay at 6 bars with that routine.
  20. Al Bundy
    Al Bundy Member
    140
    69
    florida
    if i had the extra cash I would buy one.. i have been looking at a lot of posts about them.. stupid question but doesnt the car do the same thing? run the battery down and recharge it.. then the computer tell its when to shut off and start again.... what is the benefit of the machine?
