Dynamic cruise control
Discussion in 'Prime Main Forum (2017-2022)' started by skierrob, Apr 1, 2019.
  1. skierrob
    skierrob Member
    50
    39
    signal hill, ca
    2019 Prius Prime
    Was using dymanic cruise control earlier today. My car slowed down pretty fast because a vehicle in front of me hit their brakes. When that happened, the vehicle behind me came pretty close to mine and I get a mad look from the driver. I don't recall seeing the brake lights behind me reflecting off his car. Does dynamic cruise control activate the brake lights when the vehicle slows? If not, seems like a dangerous feature. Can anyone confirm?
    Robert
    j12piprius likes this.
  2. schja01
    schja01 Senior Member
    1,836
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
  3. Tideland Prius
    16,560
    It'll come on the same way as you brake.. if it's hard enough, it will come on.
    Could the guy behind just thought you were the one braking hard and not the car in front of you? (i.e. he thinks it's your fault for braking hard and not the person in front of you)
  4. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    The brake lights do come on, but only when you exceed approximately the amount of braking you would get from "B mode". I wish Toyota had an indicator for brake lights like Subaru has with their Eyesight system.
    Tideland Prius likes this.
  5. Curlyone
    Curlyone Member
    50
    60
    Arkansas
    I've found people completely lose their minds following me when I use the adaptive cruise in stop-n-go traffic. It's like they think the closer they are to the car in front of them the faster they are going, and if I'm not doing the same I'm somehow slowing them down.
    While I don't really care what they think, or if they are ticked off by my driving, I also don't want some idiot getting "Bruce Banner" on me so I change the following distance from the default 3 to 2 or rarely 1 when speeds are 45 or lower. Even then if someone is getting obviously upset I'll accelerate a bit faster than the cruise does from a stop. The cruise seems to want to let the car ahead get to the cruising speed following distance before it speeds up much.
    Yes the brake lights come on, don't know if it's at the same point they would come on when manually braking.
    kevin.c likes this.
  6. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Adaptive cruise is great when traffic is flowing but it really isn't designed for stop-and-go or suburb streets. I mean it does have that warning when you turn on cruise control too. I noticed it keeps pace pretty well when you're driving along at speed and some minor slow downs but once it gets to stopping in rush hour it isn't as helpful. In stop and go I noticed it will wait to brake until later than I would prefer and since it waited longer to start, it brakes harder. It's almost like you're brake checking the guy behind you every time traffic drops from 30-40mph back down to 10mph or less. It also likes to come to a pretty hard stop instead of easing into a stop when cars stop in front of me. if I try to inch up it by using the accelerator it is pretty aggressive at applying the brakes again making some jerking stops.
    jerrymildred likes this.
  7. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    I really like it in stop and go traffic, but it could use some optimization. I usually set it to "1" distance if traffic isn't going too fast, but if traffic gets too far ahead I'll have to increase the distance or take over to avoid hard braking.
    When it's parked it stops slightly too far back from cars, no matter what the distance is set to. Maybe that is in case there is a flatbed truck in front of you.
    If you set the drive mode to Normal or PWR it accelerates faster than in Eco mode. I usually just accelerate manually because it's always a bit too slow, and I prefer looking at the blue background in Eco mode.
    I've tested it, and it can follow a car in front of you that's just barely inching forward, which is impressive. And sometimes I abuse it to use it as a brake hold feature, if I'm going to be stopped for a while and don't want to keep my foot on the brake. Some new cars have a button that does the same thing.
    Having driven this and the Subaru Eyesight system (on a 2019 Crosstrek), I suspect Toyota is relying too much on radar and not quite enough on the camera. Subaru's system seems to be a bit more refined, but radar is probably a technically better way to sense ahead of the car since it works better in poor visibility. I wonder how much better TSS 2.0 is?
    triggerhappy007 likes this.
  8. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Maybe he spilled coffee on his lap. :(:mad: :p
    Toyota’s dynamic cruise control can have problems with (heavy) rain weather and will disengage if you set the windshield wipers to fast. Somebody test this on TSS 2.0, or I guess I can find a TSS 2.0 equipped vehicle’s Owner’s manual and read up on it.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Same here. In my commuting, I've given up on the adaptive cruise. But I do use it in normal mode and that way I can control its behavior. We'll be making a long interstate trip in a few weeks. I'll try it again since everyone seems to be thrilled with it in those circumstances.
  10. Tideland Prius
    16,560
    I use it as a Brake Hold as well in stop and go traffic. I'll accelerate with the pedal (rather than resume from the stalk) to match the initial acceleration and then let off and let DRCC do its thing. I had someone tail really close in bumper-to-bumper traffic (probably because my gap was too large). The thing was, when I turned off DRCC (As I was approaching the merge point) and closed the gap, that person began stopping at a normal distance behind me.... must be a psychological thing.
    EyeSight doesn't have radar and relies on the the two cameras.
  11. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Methinks it has to do with the "fear of leaving enough space to allow adjacent lines of traffic to cut in front" syndrome: close it up, close it up... don't let those weenies get in! To be fair, little is as vexing as dealing with a driver trying to "thread the needle", darting back and forth between lanes showing off their white-knuckled slalom driving skills to get that extra vehicle length ahead of the rest of the well mannered pack.
  12. Tideland Prius
    16,560
    Possibly but where I was, it's two lanes and given I was in the "inside" lane (or the one by the curb), it's really rare that anyone changes lanes since we both merge at the end anyway so both lanes have an equal chance. Also, the driving style here (at least for this merge point) is such that no one really changes lanes at all. It's really refreshing.
  13. pghyndman
    498
    466
    CT shoreline
    Ahhh, Canada, that explains it... Canadians are uber-polite. Next time we make it to the Festival international de Jazz de Montréal, perhaps we can share a Labatt or three (no poutine for me though!):)
  14. Tideland Prius
    16,560
    It depends on which part of Canada. :) Even within my own city, I've seen both ends of the types of drivers.
    What? No poutine? :p Fine. Beer will suffice.
    fuzzy1 and pghyndman like this.
  15. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    I tested the cruise control in a mix of heavy snow, rain, and mist today. Visibility was a few hundred yards, and it was daytime. It was hard to see the car ahead of me, but I could see it. I had the cruise control set to "3 bars". but it couldn't see the car ahead of me at all, even as I got closer than the "1 bar" following distance and was closing in quickly. I had to brake to maintain a safe distance.
    The time I first tested it it had just started snowing, so the sensor was probably not covered or maybe only lightly covered by snow. When I got home there was 1/4 inch of slush covering the radar sensor. By then visibility had improved to about 1/2 - 1 mile, but the dynamic part of cruise control still did not work.
    I don't expect it to work when covered in snow and ice, but it should at least alert the driver when dynamic cruise control is unavailable/not working. And the sensor should be heated so it can continue to provide collision mitigation braking in icy weather. The area around the camera should be heated as well, since heat from the defroster doesn't make it behind the plastic shroud very quickly.
  16. jerrymildred
    11,517
    14,152
    Tampa, FL
    I don't think the radar can know when it's blind. If it doesn't see anything, how would it know if that's because it's blind or there's nothing there to see? But the heater is a great idea!
  17. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    It should be able to see clutter from stuff by the side of the road, street signs, etc. moving towards the car at the speed you are driving. I would expect that the signal would change if it's covered in ice.
  18. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I never used DRCC during inclement weather, so I don't know how it warns if there is a warning. But on one snowy day, I got a warning message on my MID indicating Pre-collision avoidance system is not functioning. The warning directed to clean the radar. When I stopped at a store parking, the front side of the car was covered with a slush of snow/ice. After cleaning the TOYOTA emblem, I had no more warning message the rest of the way to home. So, there is definitely a warning system for pre-collision radar. I wonder why the same type of warning does not exist for DRCC?
  19. fuzzy1
    10,498
    That strongly depends on which portions of Canada you are comparing to which portions of the U.S.
    E.g. plenty of BC-plated cars (drug runners? :)) running through here between Vancouver and Los Angeles are rude compared to the locals, but polite compared to typical SoCal vehicles. They would be a better match to the Oregon or NorCal drivers.
  20. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    I've seen a similar message when the camera is blocked. Maybe it wasn't quite bad enough for me to get a message for the radar? But it clearly wasn't working, so it should be able to alert the driver to that immediately.
    Salamander_King likes this.
