Dynamic Radar Cruise Control Question
Discussion in 'Prius v Technical Discussion' started by Cactus Hybrid, Jan 22, 2012.
  1. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    I have checked most of the posts on Dynamic Radar Cruise Control (DRCC) but none answer my question clearly.
    Here is the scenario...The vehicle in front has cruise control set at 55 MPH, I have my cruise control set at 75 MPH. As I approach the car in front of me, I feel my Prius slowing down. I'm curious what happens with the brake lights.
    I assume when the friction brakes are used, the brake lights come on as my Prius approaches the car travelling slower..Do the friction brakes remain engaged to keep the distance?
    Also, does my Prius "ride the brakes" to maintain the constant distance between me and the car ahead? Does it pulse the brakes? Does it release and engage, release and engage?
    I'm wondering if I'm driving the drivers behind me crazy or not..
    Thanks
    The link below is a nice video abut the DRCC..
    archiveman2977 likes this.
  2. PRPrius
    PRPrius Active Member
    327
    198
    1) The brake lights will illuminate if the cruise control engages the friction brakes.
    2) Depending at the approach rate, the Prius may not have to use the brakes at all.
    a) It will reduce engine power
    b) if necessary the car will use regeneration to slow the
    car at a higher rate.
    c) if higher decelearation rate is needed, the car will engage the friction brakes with brake lights.
    archiveman2977 and Cactus Hybrid like this.
  3. PRPrius
    327
    198
    As far as riding the brakes, it all deppends on the following distance. The longer the distance, the more the car can use power cuts and regeneration to slow down the car. If you are using the short following distance setting, the car may have to use the friction brakes more often. It also depends on the driver that you are following.
  4. Cactus Hybrid
    129
    46
    Thanks for the quick response....
  5. Tideland Prius
    16,155
    Why would the car ride the brakes? Would you ride the brakes following a car at 55mph? The cruise could do exactly what you do - slow the car down (and use the brakes if more reduction in speed is necessary) and then maintain speed with the accelerator pedal (you can feel the accelerator pedal move down as it accelerates).
    What he's saying is that if you use the SHORT distance, the car will have less distance to slow down by letting the accelerator off so it would have to use the brakes to slow you down. With a LONG setting, the car has much more space (as a buffer) and would be more inclined to slow down gradually.
  6. Pixel91
    Pixel91 New Member
    Marolles en Hurepoix - Essonne (France)
    I think the question is :
    "Do the brake lights turn on when the car is using regeneration to slow down ?"
    In fact, they do turn on if you press the brake pedal to slow down.
    Not necessarily when the cruise system uses regeneration to slow down.
    If you want to know, just ask a friend to follow you with his car, as you are using the cruise control !
    He can tell you by phone when your brake lights are on.
    Or temporarily connect a 12v buzzer in parallel with your brake lights ! :)
