E-85? For Prime?
Discussion in 'Prime Fuel Economy & EV Range' started by priuscatprimeguy, Dec 6, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    The Mobil Station near me has E-85 for $1.99/gal. while regular is going for $2.59/gal Since I fill up my tank once every six months is E-85 a good thing to put in my tank?
  2. priuscatprimeguy
    2,730
    2,640
    what about MPG's? better? worse?
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    From p. 719 of the Prime owner's manual-
    ●Use only gasoline containing up to 15%
    ethanol.
    DO NOT use any flex-fuel or gasoline
    that could contain more than 15% ethanol,
    including from any pump labeled
    E30, E50, E85 (which are only some
    examples of fuel containing more than
    15% ethanol).
    Montgomery, bisco, pilotgrrl and 2 others like this.
  4. Mark57
    2,945
    2,736
    OK
    RUN away from E85. @walterm nailed it above.
  5. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    E85 has about 70% of the energy of E10, so expect MPG to be that much worse until the dash lights up with warnings.
  6. bisco
    49,520
  7. fuzzy1
    10,175
    If your car was rated to use E85 (your Prius is not!), then $1.99 is still more expensive per mile than the regular E10 fuel. Considering E85's lower MPG, a breakeven price would probably be around $1.90/gal. If higher than that, get the regular gas instead unless pollution issues suggest
    If you refill your Prime just twice a year, consider going the other way -- E0 instead of the regular E10. Numerous non-automotive uses try their best to avoid the ethanol in engines that are used only seasonally, then sit in storage the rest of the year. E0 is a bit overpriced for its energy content, but is reputed to be more stable in the tank and fuel lines.
    pilotgrrl and walterm like this.
  8. walterm
    466
    202
    34
    2022 Prius Prime
    Note that finding E0 may be difficult to impossible depending on where you are - there are web sites like Ethanol-free gas stations in the U.S. and Canada and Ethanol Free Gas Stations that list stations that sell E0 in each state. For example I'm in NJ, what are listed are all marinas and airports, not helpful to fill up a car :-(
  9. Trollbait
    11,565
    Higher than E15 can be damaging to fuel system components over time. Flex fuel engines use more hardened materials, like stainless steel in their system. They also have higher flowing fuel injectors so enough E85 can be burned to get performance equal to using gasoline.
    Or simply out of the way or too expensive. The only places with it on my route are shops selling 100 octane racing fuel for $8+ a gallon by the jug.
  10. Mark57
    2,945
    2,736
    OK
    I been on several GasBuddy betas and a contributing member since 2005. We begged the newest management group to add E0 as a station option and they refused to believe it was very prevalent across the country. The beta mgr is in Regina, SK, so how the hell would he know. Out of sight out of mind attitude.
    We're lucky to have more E0 than E10. It's too bad not everyone can find it. Sadly the Puregas web site is pretty out of date.
  11. fuzzy1
    10,175
    That is certainly inconvenient for those of us with regular non-plugin Prii and must fill up every month. Sometimes even twice. :). But it is not unreasonable for Prime owners who fill up only once or twice a year.
  12. E0 is nearly impossible to get around here, unless you drive a boat to work! o_O :mad:
