E85 study, baseline
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Jun 25, 2012.
  1. bwilson4web
    16,351
    I have a kit to convert my 2003 Prius to run on E85. But first I need to establish a baseline using E10 from the same company that sells E85. I also have to confirm use of MAF as a reproducible metric for fuel consumed per HP:
    One aspect not shown in the chart is drawing over 80A from my Re-Involt traction battery. In the past, 70A had been the limit and I had thought it was part of the HV ECU programming. But it looks like the lower internal resistance modules in the Re-Involt provide an extra 10A of capacity . . . awesome!
    Some other notes:
    Temp: 77F​
    Engine rpm​
    MG1 torque​
    air flow​
    speed (mph) 45.6/46.3 -> 47 indicated -> 50 mph GPS​
    batt V​
    Batt A​
    6:08 AM​
  2. bwilson4web
    16,351
    I reformatted the data to show the climb:
    Some observations:
    • 40 seconds - the engine goes into an enriched mixture to deal with the excessive heat. Enriching the mixture reduces power yet we see the traction battery provide more power.
    • 70 seconds - the traction battery draw-down has reached a point where it has to reduce power. However, the speed effect is minimal.
    I have to do two more, max hill climbs and then add the kit and three more max climbs. Then I can run the tank dry and switch to E85. Here are the two additional runs:
  3. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Cool. Thanks as always for sharing. I'd be curious also for the downstream O2 readings if they change with E85.
    bwilson4web likes this.
