Easily Replace Rear Wiper Blade
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by keyoung, Oct 8, 2010.
  1. keyoung
    keyoung New Member
    Utah
    I bought a new replacement blade today from Auto Zone for 9.95, it is a direct replacement for the original. All you do to replace the new blade is to take the cover off at the bottom of the wiper arm. This piece just snaps on and off and covers the mounting to the window. You can then extend the arm so you can slide the used blade off and slide on the new one. This took an amazing 1 minute, once I figured it out.
    firedog73, jreed and krg03 like this.
  2. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Good to know. The last time I had to replace the rear (last year) the only place I could find it was Toyota. I don't believe it was $10.
    BTW you don't need to take the cover off if you do the wiper mod. Break the tab off inside the cover and you can lift it up (like to clean the window).
  3. firedog73
    firedog73 Junior Member
    Orlando, FL
    Thanks for the post, changing the blade is a snap--pun intended
  4. Zeppo Shanski
    Zeppo Shanski Active Member
    293
    151
    Chicagoland
    WOW. ... Just freakin' WOW.
    I replaced my rear blade today just following the pics on the blade package.
    Easiest damn anything I've ever done. ... 10-freakin' seconds ... including reading the directions. ... W.T.F.
