Easy & Safe Home Power Inverter System for Prius… Good Idea?
Discussion in 'Gen 3 Prius Main Forum' started by Gregg chappell, Oct 7, 2017.
  1. Gregg chappell
    Gregg chappell New Member
    Sarasota fl
    We recently lost our power for several days at our home in South Florida due to Hurricane Irma.
    I was able to power my TV, computers, lights and fans using an inverter system powered by the starter battery on my 2010 Prius. Before the storm hit, I spend half a day gathering materials to make the power system including a 1000 watt pure sine wave inverter, beefed up connection cables, inline fuse system, quick disconnects and terminal connectors. All of this took several hours to assemble.
    When done, the system worked great. Besides the time involved in the purchase and assembly, the only other drawback was I had to leave my Prius running for 3 days, which my research concluded was no problem for the car. But I still wanted to be able to monitor the engine temperature, oil pressure, inverter heat, whether the battery was being charged and how many watts of AC power the house was pulling.
    In spite of knowing it was not an issue, I still wanted to keep an eye on my gauges. After several trips to the car in the pouring rain to check my dashboard, I realized there needed to be a better way. So I started to design an app that would feed me all the vital information. Once I had all of that on paper, I went a step further and designed a no-hassle, easy to install, 1000 watt pure sine wave kit for Prius owners.
    Is this system a product that Prius drivers would be interested in owning?
    I would greatly appreciate your input…..
    Thank you,
    51,155
  3. Tideland Prius
    16,445
    I'm leaving this one here because you have a 2010 Prius (3rd generation). Please don't post across multiple forum. It makes you look like a spam robot.
    Grit likes this.
  4. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    It must have been difficult to go through the hurricane and good to know you survived through it. To answer, no because torq & techstream exist for free, depends on your 'network'. And a generator with supplies of gas oil would be much better in my opinion.
  5. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    You are using your starter battery to power the inverter? Wouldn't it be better to pull power from the battery pack? The battery pack is designed for charge / discharge applications where the starting battery is just a starting battery and even if you use the optima it isn't designed for lots of charge / discharge cycles.
    mrbigh and Prodigyplace like this.
  6. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Wirelessly? Will it need a dongle? Can you make it work for any Toyota?
    This market has lots of existing equipment. Can yours be somehow superior?
    The traction battery can give you more power, but taping into it is actively dangerous, probably beyond the average owner.
  7. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Get an OBDII plug with bluetooth (which supposedly gets 30 meters of range) and install an app on your smartphone that reads its data.
    kc410 likes this.
  8. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    That is exactly what I did after hurricane Irma - PriUPS in action | PriusChat
    OBD2 adapter & Torque on the phone.
    Bluetooth worked very well from inside the house to the Prius in the driveway - almost too well - I had to turn off BT in the phone to be able to talk on the phone! When I received a call the audio was out in the Prius while I was wondering why the phone was broke :-/
  9. bisco
    51,155
    none of that is necessary. monitoring your cars data while using it as a generator is like monitoring it while driving.
    great for geeks, but the car will perform as long as it has gasoline, without issue.
  10. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    Unless the Prius is sitting in full sunlight with an operating UPS producing a fair amount of heat & one forgets to leave the AC running in the Prius to keep the UPS & the traction battery somewhat cool.
    Even at night, the inside of the Prius gets very warm with an operating UPS because there is no air circulation.
    For lower power overnight operation I was able to run the fan on medium speed & outside air which would keep the inside temps somewhat reasonable.
    I noticed this problem in two ways: 1) when first set up I would log the temps inside & outside as well as actually sit in the Prius every 15-20 minutes. I quickly noticed the interior temp rising. 2) this was soon verified watching the traction battery temps slowly creep up.
    Outside temps were only getting down to 79- 80°F!
  11. bisco
    51,155
    agreed, forgetting to set the a/c would be a faux pas.
  12. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    I have a small 900 watt 2 stroke generator that I bought for $90. I didn't need to use it for Irma, as I have a bigger generator. That said, I have used it to run a 5000 btu A/C and a 700 watt microwave ( not at the same time) in my camper. I got 8 hrs running the A/C at night from a 1.2 gal tank. It makes sine wave power, too.
    If the inverter is placed inside the car, it could be a fire hazard- a 12 volt battery can quickly melt shorted wires/circuits and start a fire in about one minute. A 1000 watt inverter rated for constant usage, would be RV grade and is not cheap.
    An inverter thread from a few days ago, mentioned that their Prius ICE didn't kick in to recharge the 12v battery until it got down to 11.5 volts, which is , like 90+% discharged- if this is done repeatedly the life of a lead acid battery will be severely reduced.
    Product liability insurance would be a good idea, in case a Prius does catch on fire while an inverter system (made for a Prius) is in use.
