EBH installed... wow, easier than I thought!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by likesmpg, Jun 23, 2007.
  1. likesmpg
    likesmpg Junior Member
    49
    Irvine, CA
    I did the install from the top (after removing the cowl) and it was a piece of cake. Got a little worried reading all the posts about problems but it was very straighforward. I am excited to try it out and see if it makes a difference. My MFD tanks have been 58.5, 61.7, 63.4... maybe this can push me into the 70's !?!? If anyone in SOCAL needs help I'd be glad to do it for them. Happy gliding...
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Great job! You can now do all the installs west of the rockies.
    Wayne
  3. likesmpg
    49
    Irvine, CA
    Evidently ~45 minutes isn't long enough for it to do very much... I'll have to try plugging it in a little sooner or get a timer. Sounds like a good number would be 2 hours of warmup? Thanks,
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yea, a timer and 3 hours seems to be the best bang for the buck.
  5. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    LOL! It looks like in your location you won't be needing to push your engine out of sub-zero temps too often. I'll have to install an EBH just to get my winter driving over 38 mpg :(
  6. likesmpg
    49
    Irvine, CA
    60 minutes this time and I noticed a difference. first 5-min. bar which is usually 25-30mpg was up around 35-40mpg! And I could get into an engine-off glide a couple signals sooner that normal. Good stuff. Tomorrow I need to not leave the hood up while heating because I think some of it is escaping. I'm already getting tired of opening the hood every morning so I may re-route the wire to next to the foglight. I was just worried I would not notice it was plugged-in one day and drive off :huh: Do you guys have a fail-safe 'not drive off while plugged-in' method? Thanks.
  7. kdk84
    kdk84 New Member
    113
    Michigan
    to install the ebh from the top do you need to remove the hood too or just the black cowl and wipers??
    I just received mine in the mail, thanks.
  8. LYLUVLY
    LYLUVLY New Member
    150
    Huntington Beach, Ca
    Is the EBH the same as an EV Kit?
    I sure would like to have one installed.
    I would be glad to pay you for your time and expertise if you can help out.
    1. where should I go to buy an EV kit?
    2. How to contact you when I get the kit?
    I am in huntington beach, ca . email me at: [email protected]
    Thanking you in advance
    Never answering my post.
    I just figured it out: EBH stands for Engine Block Heater [yes?]
    EBH. I do not need.
  9. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(kdk84 @ Jun 26 2007, 07:17 PM) [snapback]468561[/snapback]</div>
    Check Hobbit's write up of how to do the top down method, I think I remember he removed the hood for better access. Remember, when you put the cowl back on, that all the seals/weatherstripping are re-done correctly, there was a TSB for '04 prius for water leakage at the cowl that required extra weatherstripping.
    Having said that, where in Michigan are you? Would you like it done in 30 minutes? The kids want to see their grandparents soon and a side trip won't kill them.
    Wayne
  10. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    If you're worried that you will forget to unplug your EBH, either drape the cord over the driver's side mirror or make a little sign saying UNPLUG ME & put it on the windshield facing inward when you plug in the car. Those of us having senior moments may wish to do both :D
  11. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I only removed my hood to get better *picture* access! It's not
    necessary if you're just installing the heater. The amusing pix
    that were never taken would have been of me laying across the bumper,
    inverter, windshield, etc in all kinds of, uh, compromising positions
    to get the shots I wanted...
    _H*
  12. likesmpg
    49
    Irvine, CA
    Got a ~40mpg 5 minute bar this morning! I'll be out to get a digital timer this weekend, any suggestions? I'm sure Lowe's will have something that will work for around $20?
  13. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(likesmpg @ Jun 28 2007, 12:35 PM) [snapback]469464[/snapback]</div>
    I hope you purchased a timer that has a higher wattage rating than the EBH. How many watts is the EBH? Some timers are not rated for a purely resistive load(Carbon film resistors) Most are rated for an inductive and resistive load like fans or electric motors. Your heater is 100% restistive load. Keep in mind.
    D Rock
  14. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    <div class='quotetop'>QUOTE(LYLUVLY @ Jun 26 2007, 09:04 PM) [snapback]468636[/snapback]</div>
    In California you need the EBC (Engine Block Cooler) [yes!] :rolleyes:
  15. likesmpg
    49
    Irvine, CA
    <div class='quotetop'>QUOTE(D Rock @ Jul 5 2007, 04:55 PM) [snapback]473738[/snapback]</div>
    The heater is 400W, timer is rated 1800W Inductive and Resistive, but also says 500W Tungsten something 'er other. So far so good. I got a ~45mpg bar yesterday morning with the timer coming on 1.5 hrs. before departure. I like it... just need to re-run the cord so I don't have to open the hood every night now :(
  16. likesmpg
    49
    Irvine, CA
    Got my first 50+ mpg 5-minute bar this morning! It was maybe 52mpg and mostly because I made it through a key stoplight, but I am still very pleased.
