ECO Accelerator Guidance bar minimization after take-off
Discussion in 'Prime Technical Discussion' started by srivenkat, Sep 5, 2020.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I am trying to make sense of the guidance bar becoming minimal after allowing for an accute acceleration phase in the take-off (from a stop) stage. Wondering why this is so. I have noticed that after becoming minimal, the bar slowly creeps up as I accelerate right below the threshold. Does the traction battery directly drive the electric motors or is it inhibited by the eCVT?
    Or is there some kind of warm-up needed for the battery, that Toyota ignores for the initial take-off, since otherwise, in the hands of some folk the Prime might become a PIA for the following cars.
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I really don't have a clue what logic is behind the programming for the guidance bar since it seems to act so differently at different times but similar circumstances.
    The electric motors are the heart of the eCVT along with the planetary gear set. MG1 and MG2 get power from the battery as regulated by the inverter under the command of the hybrid ECU working out how best to execute the command your right foot has given.
    srivenkat likes this.
  3. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    I haven't found that feature to be useful at all. I should probably disable it.
  4. srivenkat
    596
    93
    IL
    Perhaps @bwilson4web has an insight to share. Or perhaps Prof. Kelly at Weber State.
  5. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    I always thought that minimal bar indicates timing to let the foot off the pedal after reaching the initial desired speed. Of course, that does not always correspond to the actual driving situations, like going uphill after starting or needing to marge on the highway.
    Can that feature be disabled? What would it show on HIS then?
  6. bwilson4web
    15,524
    My last Prius drive was 1.5 years ago so I don’t have current data or a car to test. My foggy memory is the control laws still keep the ICE in a relatively efficient range. But you can’t avoid paying the aerodynamic energy cost.
    Tips and srivenkat like this.
  7. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    I think it can be disabled. The background becomes solid black instead of the blue bar that moves randomly.
    Toyota is not known for the quality of their software. I wouldn't put much value in what it's telling you.
    srivenkat and bwilson4web like this.
  8. srivenkat
    596
    93
    IL
    Thanks. I forgot to mention in my original post that I was referring to the ECO guidance bars for EV mode only, although the same could apply to HV/ICE. I could understand the minimal acceleration needed with ICE in a higher "gear" after the initial take-off, but had trouble envisioning the same in EV mode since I was under the impression the drive motors are directly driven without any gears being involved, but per @jerrymildred it looks like there are gears involved in EV mode as well.
  9. srivenkat
    596
    93
    IL
    To the extent I have done EV drives, it seems to me that driving according to ECO guidance (or not) strongly influences the Score card.
  10. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    I don't use those displays, if you scroll up or down you can have something that doesn't distract you. I blend within traffic, the car is amazing in MPG, a little more or less doesn't make a big difference.
  11. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    That's another feature that I ignore. For example, leaving work there's a traffic light at the bottom of a hill. I need to get up the hill, and I need to get up to the speed limit before the car behind me gets impatient. I've seen the score go as low as 4/100, just accelerating briskly up that hill in HV mode but not flooring it or anything.
    Just drive as smoothly as possible and accelerate and brake as gently as you can without impeding traffic, and you'll get good efficiency.
    jerrymildred and srivenkat like this.
  12. jerrymildred
    11,511
    14,113
    Tampa, FL
    A high ECO score does not always equate with high mpg or m/kWh. I have gotten to work in the morning with a 90 ECO score and only 4.8 m/kWh and gotten to work with a 70 ECO score and 5.3 m/kWh. (Numbers grabbed from air (GFA) since I didn't record them, but representative.)
    This! (y)(y)
    Watching traffic is, of course, job one. If I watch anything, it'll usually be the instantaneous mpg or m/kWh gauge, but I also glance at the HSI indicator to keep it as close as I can to the line between ECO and CHG. But if there's traffic to deal with (or intersections that might hide surprises), instruments become totally unimportant.
  13. jerrymildred
    11,511
    14,113
    Tampa, FL
    I should have linked this before. You'll see that the PSD is what makes the whole thing work.
  14. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    I'm pretty sure all of us who drive Primes, still wonder what some of the gauges are trying to tell us.
    For me the key is to lay low and pay attention. The mystery usually gets demystified with time.
    As far the the Prime becoming a PIA for following drivers, that's all the responsibility of the Primes driver.
    If you don't understand / like why Toyota included the ECO bar the way they did, flip to another screen.
    Heaven knows, there are enough of them to keep most drivers happy.
    srivenkat and jerrymildred like this.
  15. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,550
    720
    Or why they do weird things. That eco guidance bar can be "tricked" reliably whenever you have to brake without coming to a stop (like when a traffic light turns green before you stop). The eco guidance doesn't seem to comprehend that situation and will guide you to continue at your current speed and doesn't allow for acceleration to resume your previous pre-braking speed.
    jerrymildred likes this.
  16. Bill Norton
    Bill Norton Senior Member
    1,844
    603
    MONW, Ks.
    Some say it's that display is what give the Prius the 'Slow' reputation.
    Some drivers use it and then drive slow instead of just driving normally.
    I guess saving 50 cents a week is a big deal to some....:p
  17. PiPLosAngeles
    1,550
    720
    It's far more dramatic than that. If I drive 'normal' with the flow of traffic, in HV mode I get about 50 mpg. If I follow the display (or less) and stay behind trucks going 60 mph I can usually get 75 - 80 mpg. That's two tanks less gas per month driving 21,000 miles per year.
  18. Bill Norton
    1,844
    603
    MONW, Ks.
    Going 60 mph close behind a truck on the highway is...... Not for everyone.
    "If you're not the lead dog the view is always the same".:rolleyes:
    We have to ask "How close?"(n)
    But if you say it's 2 tank fulls a month,,,? That's a lot of gas to blow through your gasser. Stay the course, follow that truck.
  19. PiPLosAngeles
    1,550
    720
    Some people like to be at work 6 minutes earlier and pay extra for the privilege. Not sure what that's about.
  20. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    I always wonder if following trucks is worth the extra rock chips on the paint and windshield.
    vvillovv and Tips like this.
