Eco mode in PIP--advice please
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by oswaldjacoby, May 8, 2012.
  1. oswaldjacoby
    oswaldjacoby Junior Member
    united states
    Would love some advice about how to best use Eco mode in the PIP. Is there any point to eco mode when you are in EV?
  2. maverickf
    maverickf New Member
    113
    Southern California
    I would like to confirm if ECO mode works with EV mode. I tried driving in EV with ECO on and was able to get 1-2 miles more.
  3. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    I have had "ECO" on since day 1, it used to just change the gas pedal "feel" and delay engine start a bit longer on my 2010 Prius, not exactly sure what it's doing on the PiP, but I am getting great MPG...
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    ECO mode reduces the input sensitivity of you "drive by wire" gas pedal.
    In other words, for any given depression of the gas pedal, ECO mode reduces the power demand input to the car's ecu.
    It makes it easier to reduce and control your power demand to the engine/drive, for more economical drive. Also make it easier to stay in EV mode and attain and maintain glides and stealth. Makes it easier to prevent the engine from starting while driving around.
    I leave it ECO mode all the time.
    Besides, in a tight situation, if you press the pedal far enough you'll still get all she's got anyway. You just have to push further.
  5. wiggleman
    wiggleman Junior Member
    86
    Arlington VA
    2015 Prius Plug-in
    I use Eco when I'm driving strictly on city streets. When I am about to get on a freeway, I switch to Power for the acceleration needed to get on (east coast drivers don't usually slow down to let you on!). On the freeway I leave it on HV/EV. The manual says that if you drive below 62mph, then the car may stay on EV - my freeway driving here is by necessity over that limit at times, so the HV/EV setting is fine for that situation.
    I really do love those options.
  6. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    All I note with any of the buttons is an increase in RPM. So PWR knocks the same depression up in the 3-4000 RPM range. ECO appears to do the opposite. From a steady depression, that switch will knock the RPM down to about 12-1500. Hardly scientific, but it's observational data at its best.
