Eco Mode vs Normal
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Jun 25, 2017.
  1. stevepea
    stevepea Senior Member
    533
    581
    When in either HV or EV mode (though especially curious about HV):
    Is there any difference between Eco Mode and Normal Mode other than the psychological trick of making the driver have to push down more on the accelerator pedal in Eco Mode to get the same amount of acceleration?
    So other than the accelerator pedal pressure difference, does anything about the car's software or thought process change between Eco Mode and Normal Mode? Is the car less economical in Normal than Eco Mode? Or is it exactly the same (other than the amount of pressure needed on the accelerator pedal?)
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    On my Gen 4, the radar cruise control does not accelerate as briskly when in Eco drive mode.
    bwilson4web and stevepea like this.
    49,504
    the hvac is suppressed.
    stevepea likes this.
  4. Prodigyplace
    11,696
    11,318
    Central Virginia
    hvac Eco mode for climate control is controlled separately from drive mode in Gen 4 and, I assume, Prime
  5. bisco
    49,504
    interesting. so it's just the go pedal and cc?
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Drive Mode Eco defaults HVAC to Eco mode. Normal and Power do not. You can, of course, override the default.
  7. Mendel Leisk
    38,735
    To muddy the waters, aren't fourth gen "modes" all shifted towards the aggressive end of the spectrum, by about one mode?
    On 3rd gen, I tried ECO at first, then shifted back to Normal mode after about 6 months, didn't seem to effect mpg. The main feature of ECO was inordinate and tiresomely long gas pedal travel, way more than necessary for easy modulation.
  8. Lee Jay
    5,850
    4,024
    Yes. G4 Eco is like G3 Normal and G4 Normal is like G3 Power.
  9. Mendel Leisk
    38,735
    So, G4 PWR is basically "mind yur belted in now" mode?
    I guess then, I'd vote for ECO in gen 4, I like the linear feel of Normal on gen 3.
  10. Lee Jay
    5,850
    4,024
    I like Eco because most driving gets done at low throttle settings and Eco mode makes it less touchy at those settings and is thus easier to control. Normal is pretty touchy and Power is crazy touchy.
    alexcue and Prius from Dad like this.
  11. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I know, switching from Eco to Power Mode when climbing the Grapevine is just a blast! It makes it feel like you got some power under you! I know, I know all in my head.
    Prius from Dad likes this.
  12. CharlesH
    2,785
    1,152
    Roseville, CA
    So the bottom line, is that you have the option to set HVAC Eco mode to either be always on, or on only in ECO drive mode? In the GEN 3, you get HVAC Eco mode only when in ECO drive mode.
  13. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    I've been driving in ECO in my Gen3 for ~ 5 years and do the same in the Prime, works fine for me ... and I know if I really need to accelerate fast, i just have the push the pedal harder
    #13 joachimz, Jun 25, 2017
  14. Prodigyplace
    11,696
    11,318
    Central Virginia
    My son thinks Gen 4 Eco is like PWR mode in his 2015 Prius v.
    Although going into Eco driving mode may change the climate control, you can change it back to normal.
