ECO Mode: What's the data?
Discussion in 'Gen 3 Prius Main Forum' started by Bgustafson, Mar 27, 2018.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    I'm curious who's done the math using ECO mode? I personally hate driving in ECO mode unless maybe on the highway, which in that case it doesn't make much of a difference in engine performance or gas savings. I understand how ECO mode works; I'm more curious if anyone has seen a significant benefit in gas savings? Also it definitely seems to tax the HV battery a lot more -- so I wonder if that's a tradeoff?
    Driving in ECO mode is sooo unsatisfying. :sleep: I could maybe justify it if drivers were reporting major gas savings. I'm not a heavy footed driver, but I do enjoy a nice pickup in my car. Especially coming from a turbo Mini Cooper. :whistle:
    FuelMiser and kc5dlo like this.
  2. Mendel Leisk
    40,574
    As far as I know, the main thing it does is put the gas pedal in "passive aggressive" mode, ie: to get a half-decent reaction out of the gas pedal takes some real exercise. For me this got old fast, I find Normal mode (neither ECO or PWR) just fine, very linear.
    It also is purported to change the AC behavior a bit, and perhaps cruise control as well, but meh.
    taxibuddy likes this.
  3. ChapmanF
    17,326
    It definitely caps the top exertion of the air conditioner and blower; I was in Richmond, VA last summer and had to turn ECO off for the A/C to keep up.
    It also locks out the electric heat elements, so you get none of that boost to the heat while waiting for the coolant to warm up. Since learning that, I've been making a point of turning ECO off whenever I start the car and have to put on front defog to clear the windshield. I used to wonder why it was taking so long....
    -Chap
    Bgustafson, Mendel Leisk and bisco like this.
    51,141
    aside from the a/c, it is just remapping the pedal. so there would be no way to scientifically measure mpg in each mode.
    an experienced prius driver can accomplish the same mpg's in any of the 3 modes, except for the limited hvac hit.
  5. Mendel Leisk
    40,574
    I found no discernible diff, fwiw. Used ECO pretty much solid for first six moths, not since. If anything, mpg improved, but just from getting the hang of it, different driving patterns, whatever.
  6. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I have had my prius for a few years and mostly have had it in ECO mode. Kept forgetting to try turning it off to help the HVAC when needed till once this winter and noticed significantly more heat. Left it off most of the winter without a noticeable difference in mileage. I am curious what mode in theory would be best when stealth camping and leaving the car in READY mode all night. Would one mode be better than the other?
  7. bisco
    51,141
    hvac would be the only thing affected. but it wouldn't be any different than if you turned it down manually.
    heat and a/c require more engine run time.
  8. ChapmanF
    17,326
    I don't know how to be sure that it would or wouldn't. It locks out the electric elements, for example, which you don't otherwise have manual control over. I don't know whether its caps on compressor or blower rpm are quite equivalent to anything you can do at the controls, either. I think they're not: with ECO off, it will run the compressor at whatever power it thinks is needed to reach the temp setting you've entered. You could simulate the effect of a lower compressor power cap by paying close attention and fiddling your temp setting up and down as needed, but ECO will just enforce the cap while you leave the controls alone and do other things (or sleep).
    -Chap
  9. bisco
    51,141
    that's what i said, with less verbosity.:)
  10. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    I think it really depends on driving style. It’s actually kind of nice that they offer different pedal feels. I actually get a few MPG better in power mode, and as a bonus I’m not jerking myself backwards in the seat when I drive other cars either like if I get used to driving the Prius in eco or normal mode.
  11. ChapmanF
    17,326
    Ah. I thought you were saying "it wouldn't be any different than if you turned it down manually" and I was (verbosely?) pointing out some of the ways it's different.
    -Chap
  12. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    The most compelling situation/advantage that power mode better for FE #s than eco when hauling heavy items in city limits with my gr/andpa style of driving. You get up to speed faster and coast distance is longer with weight momentum. The longer gradual time to get up to speed limit with ECO actually lowers my MPGs compa/red to power mode getting up to speed faster. If hauling 2 or more passengers and/or extr/a trunk weight, I pick power mode.
  13. Mendel Leisk
    40,574
    All I know is ECO is hard on my right leg muscles: takes an inordinate amount of pedal travel, way more than necessary.
    Reminds me of poorly designed software, with redundant/repetitive actions, that you always need to take.
    Bgustafson likes this.
  14. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    ECO mode is sooo lethargic. Tried it once or twice, unimpressed, never used it again. I keep it in normal mode. No buttons to fuss. :D
    Bgustafson and Mendel Leisk like this.
  15. Mendel Leisk
    40,574
    That's another thing: looking down to find those buttons I'm as likely as not to end up in a ditch.
    Bay Stater likes this.
  16. MelonPrius
    MelonPrius Senior Member
    839
    514
    Las Vegas
    This was my experience, too. Plus, I became that stereotypical Prius driver that pissed off the other drivers on the road for accelerating too slowly. I don't know how ECO users can keep up with traffic without putting the pedal to the metal.
    I'll try ECO again during the upcoming summer, combined with cruise control. If I can save a bit on AC without feeling much difference, I'll take it.
  17. Mendel Leisk
    40,574
    I can still piss people off in normal mode, thank you very much. :)
  18. Bay Stater
    534
    771
    Central Mass
    I pissed off motorists just for driving a PRIUS!!:ROFLMAO:
    Chris Maynard and Threej like this.
  19. Bgustafson
    259
    222
    Chicago
    ROFL! It’s SO true though!! :ROFLMAO: I was just telling my wife the other day how people genuinely have a hatred towards Prius drivers as a whole. No matter how fast I drive....They just hate me!
    Chris Maynard, Threej and Bay Stater like this.
  20. MelonPrius
    839
    514
    Las Vegas
    But cops don't give us a second look when we drive by.
    Chris Maynard likes this.
