ECO setting for air conditioner
Discussion in 'Gen 2 Prius Technical Discussion' started by etyler88, Nov 8, 2007.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I had not heard about this. The HyCam airconditioner has a setting for more economical use.
    "Because there are times when the gas engine shuts down completely to conserve fuel, Toyota engineers have designed the air conditioning and power steering systems to be driven electrically. There is also an ECO button which can control how much energy is being used by the climate control system."
    http://www.cnn.com/2007/LIVING/wayoflife/1...brid/index.html
    Is the Prius in ECO all the time? I wonder if the Prius will be able to have upgrades by "reflashing" the computer, a software upgrade.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(etyler88 @ Nov 8 2007, 11:59 AM) [snapback]536829[/snapback]</div>
    Sounds like the Prius AUTO/AC setting.
    Camry Hybrid has an "ECO mode for the climate controls where unless the temperature selection is on absolute maximum, minimum, or front defrost setting the climate controls operate in a more efficient manner."
  3. Tideland Prius
    16,014
    No, it's different. The ECO button on the TCH just limits the amount of juice drawn from the battery so the climate control won't turn the fan up too high or draw too much power from the battery to power the A/C compressor.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You can pretty much get the same effect by asking for moderate
    cooling, and keeping the fan speed on the low side.
    _H*
  5. KMO
    KMO Senior Member
    1,380
    326
    Finland
    2023 Prius Prime
    I thought it also prevented the engine from running just to provide heat (or at least made it less prone to doing so).
  6. Tideland Prius
    16,014
    <div class='quotetop'>QUOTE(KMO @ Nov 8 2007, 03:16 PM) [snapback]536935[/snapback]</div>
    less prone is more likely. I mean, I don't think it's gonna let you freeze your butt off.
  7. seasalsa
    1,278
    Kent, WA
    The engine does not have to run just to provide heat. There is an electric pump to circulate hot water to the climate control system when the ICE shuts off.
  8. KMO
    KMO Senior Member
    1,380
    326
    Finland
    2023 Prius Prime
    But it does run just to provide heat. Try it for yourself - toggle the AC/AUTO button when the interior is significantly cooler than the target temperature, and the engine will stop and start.
    If it wants to warm the coolant up to provide cabin heat, it will run the engine. If the coolant is already "warm enough" (however warm that is), it will leave the engine off. At least until the coolant gets cooler.
