ECU error code: P3000, P3140, P0A84
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brando714, Jun 10, 2020.
  1. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Hello there members. I recently purchased an 04 Prius and did a lot of maintenance to it except for the battery pack. I did buy a bluetooth OBD2 and TorquePro and Dr. Prius (both the paid version). No engine lights are on and no code pops up with OBD2 scanner but after scanning battery life with Dr. Prius, the codes mentioned in the title (P3000, P3140, and P0A84) popped up. Please guide me through what I can do to fix these problems thank you. P.S. I would be posting this same post on the Main Chat as well so sorry if you see this same post on here.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Looks like the hybrid battery fan isn’t working properly. Pull the fan and clean it, and inspect the connectors for corrosion.
    SFO likes this.
  3. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    You know what? I did recently clean the fan and noticed corrosion on the harness and posted a thread about that. I ended up buyong DeOxyit spray so I will be doing that tomorrow. Thank you very much
  4. George W
    George W Senior Member
    911
    514
    San Antonio
    Baking soda, water, and an old toothbrush would work better
  5. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Damn, I received the DeOxyit spray off Amazon for $15 already. I saw a cheaper alternative but the spray can at least lubricates and protects there electric parts as well, not just clean, so I guess in the long run hopefully it'd be worth it. Thanks for your input though. By the way, I used scented baking soda for the interior of my car and vacuumed it the next day because it absorbs bad odor
  6. George W
    911
    514
    San Antonio
    Vinegar or lemon juice on a toothbrush also works with corrosion on terminals, if you're Deoxit runs out. But then you need the baking soda to neutralize the weak acid left behind.
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Uh I don’t know if I’m seeing this correctly, but the female plug looks so corroded, it has a pin or two stuck in to it. If I so that would totally be an issue!
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    If nothing else, the corrosion is problematic;).
    Definitely explains a few things(y).
  9. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Definitely! Some spray isn’t going to help that. He very well may have to get a new connector or re wire it.
  10. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    Please do not do this. Pick a forum and post once.
  11. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    UPDATE: Hey guys! So I sprayed DeOxyit to the contacts on the harness I provided the pic with and it worked!!! I did a quick burst on both ends of the contacts, used a toothbrush to kind of brush it off lightly, did another quick burst and then plugged/unplugged about 3-4 times. Using the same Dr. Prius that read the 3 codes, I scanned it again and it is gone now. Just for extra measures, I drove 25 miles on the freeway and rechecked it, and it is still gone. Yay yay!
    Aaron Vitolins likes this.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Unless that spray somehow repaired that connector AND the cause of the corrosion, the codes will come back eventually.
    Judging by your forum activity, it sounds like you want to be very pro-active with this car (and that's a good thing). So, I suggest you determine the state of your HV battery. Is it original, used or what? The best way is to pull a code number of the top of one or more of the modules. It's actually a date code and they should all match. Rebuilts won't.
    GOOD LUCK!
    SFO likes this.
  13. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Hi. I purchased the paid version of Dr. Prius and it shows that my battery is at 58.30% fair condition. When I have time, I am going to further look into reconditioning the battery with equipment's to charge/drain I will look into if other's think it will be worth it for my state of battery or to just wait for some time and then swap it out with a reconditioned one
