ECU pinout
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Vege8, Aug 10, 2018.
  1. Vege8
    Vege8 Junior Member
    New Zealand
    Hi I am trying to install Cruise Control to my JDM Prius PHV.
    I have found the wiring instructions for the 2005 Gen 2 Prius but not 100% sure that the ECU pins are the same for the Gen 3 and/or Plug in Prius does anyone know or have access to the ecu pinouts for the PIP
    Here is what I have found online - in the Gen 2 it is H14 Pin 13
  2. Vege8
    Vege8 Junior Member
    New Zealand
    Screen shot
  3. aucklandprius
    aucklandprius New Member
    Auckland, NZ
    @Vege8, did you get anywhere with this?
  4. Vege8
    Vege8 Junior Member
    New Zealand
    Thanks to Greg we now both have Cruise control working.
    The Pin is Pin 22 on the top plug of the ECU that we find at the left behind the glove box.
    We bought our Cruise Control stalks from Aliexpress
    And followed the installation instructions from Prius Chat (reference 87017
    Some new Model PIP's/PHV's might find that their ECU has 5 Plugs like this;
  5. aucklandprius
    Auckland, NZ
    Thank you guys - I'll check if my pinouts match and see if it works for mine. I have a PIP (Prius Plug-in Hybrid PHV) ZVW35.
  6. aucklandprius
    Auckland, NZ
    Success! It works! Thank you for sharing this!
    Raytheeagle likes this.
  7. Kavin
    Kavin New Member
    Monday
    Srilanka
  8. Mendel Leisk
    38,634
    have a look through the attached. If you need more let me know.
    Kavin likes this.
  9. Kavin
    Kavin New Member
    Monday
    Srilanka
    Thank you very much.
